Error Message
Results 1 to 15 of 15
Thread: Error Message
    Jun 2006
    Whoops sorry it's a 16F688.
    Compiles fine here.
    Are you sure the HighJack routines are installed in the library?
    Jun 2006
    That's what the .lib looks like. I put the other 2 files that were in the zip file in PBP folder. I don't have any hair to pull out else I would. HA HA!!
    OK, got the file, but removed it. Darrel Taylor.
    The .lib file looks good.
    Is there any chance that you have more than one installation of PBP.
    I can duplicate your error message from post#1, IF I compile with the default PM.exe assembler, and also do not have the HighJack routines in the .lib file. Otherwise it always compiles NP.
    I have an installation of every version of PBP since 2.40, so I often have a problem of MicroCode Studio being pointed to the wrong version. And not every version has HighJack installed.
    In MicroCode Studio, goto View | Compile and Program Options ... | Compiler Tab and verify that it's pointing to the same folder that the .lib file shown was in.
    Jun 2006
    Only have 1 PBP. Only had it for a week just switched from PBC.
    Jun 2006
    Also on compiler tab pointing to PBP folder.
    I'm affraid you have me at a loss. Out of ideas at the moment.
    Could you email me the .LST file?
    darrel at pbpgroup.com
