Error WINDCH~1.ASM 403:[235] opcode expected instead of 'error'
Got this error message using LCD_AnyPin.pbp is this normal?
The compiler and assembler make about 7 different files when you compile your code all having the name you chose for your program, with differing sufixes. This message points to the .asm file line 403. Open that file and look at which line of code correlates to it in your .pbp sourcecode and try to figure out the error, likely something as simple as a missing space, failure to use caps a comma etc. . .
Compiles fine here.
Are you sure the HighJack routines are installed in the library?
<br>
That's what the .lib looks like. I put the other 2 files that were in the zip file in PBP folder. I don't have any hair to pull out else I would. HA HA!!
OK, got the file, but removed it. Darrel Taylor.
The .lib file looks good.
Is there any chance that you have more than one installation of PBP.
I can duplicate your error message from post#1, IF I compile with the default PM.exe assembler, and also do not have the HighJack routines in the .lib file. Otherwise it always compiles NP.
I have an installation of every version of PBP since 2.40, so I often have a problem of MicroCode Studio being pointed to the wrong version. And not every version has HighJack installed.
In MicroCode Studio, goto View | Compile and Program Options ... | Compiler Tab and verify that it's pointing to the same folder that the .lib file shown was in.
