The worst programmer ever to grace this forum - ME!
Results 1 to 40 of 50
    Apr 2009
    Boise, Id
    I had the same trouble when I used "Debug" and interupts, using the HSEROUT worked great. You can read about it in a thread I had
    "DT Interrupt and Elapsed Time Running Slow"
    http://www.picbasic.co.uk/forum/showthread.php?t=11056
    hope that helps,
    Shane
    Mar 2009
    Hi Shane...thanks for the info.
    Just to report that my PC onscreen text from my PIC is no longer garbled with (heaps) of interupts ...using the HSEROUT command (9600 baud) coupled with the PICKit2 Uart tool - not a MAX232 chip in sight :-)
    The last thing I now need to achieve is user input!
    Essentially, when my program first starts, I need to prompt the user for input (using the HSERIN or SERIN command)- the input will always be three characters long - terminated with a CR.
    I've googled a fair bit on this one (HSERIN & SERIN), but surprisingly, I've not find anything that a newbie like myself can latch onto easily!
    Could anyone be so kind to help out?
    Mar 2006
    China
    Default or is it?
    Just because the lid is on doesn't mean that the box is emplty.. there might not be a max232 chip, but something similar is inside the pickit2 providing the same function..
    Mar 2009
    Quote Originally Posted by Jumper View Post
    I realise that.
    The thrust of my joy being, that as a newbie who has already outlayed for a Pickit2 starter kit...that I can actually use that to 'glue' my PIC to my PC (h/w serial comms wise)...ie I don't have to buy extra IC hardware, veroboard etc! (nor have my time sumped having to figure out how to connect it all together - I have enough on my plate as it is with PICs!)
    How can I convert my three character string (which will always be numbers) into an actual number that my program can use - I guess what i need is a way of converting a string into a number? (or perhaps a way of taking the input as raw number vs the string method I'm using?)
    My input doesn't work as a number wrt my program, as when I run it my counter starts at a different number to what I input (if for example I input 0032, the count below starts decrementing at 48, in fact it starts at 48 no matter what number I input!!)[/I]
    Here's what I'm doing .....
    turns_required VAR BYTE[3]
    counter var byte
    counter = 0
    pause 800
    HSEROUT [13,10]
    HSEROUT ["Enter Number of turns required (with a leading 0)>>>", 13,10]
    Main
    HSERIN 5000,finish,[WAIT("0"),STR turns_required \3]
    HSEROUT ["Number of turns will be.... ", STR turns_required \3,13,10]
    counter = turns_required ' this is the key bit that isn't working as turns_required is a string
    count_loop:
    counter = counter -1
    HSEROUT [DEC COUNTER,13,10]
    pause 200
    GOTO count_loop
    Mar 2009
    Oops, that last posting of mine missed a middle bit out! It should have read more like below...
    I've kludged the following code taken from here & there (plagiarism is alive & well!), towards getting the HSERIN working to fit my needs.
    I'm using HSERIN to take 3 characters (which always will be numbers), input from my PC keyboard into my PIC. I'd then like to use these three separate numbers & combine them into a variable. All my serial end to end connectivity is is now working (no gobbledegook etc)...I'm happy with the signal flow aspect, fuses etc - ddata is moving to & fro fine - my query is now a basic simple programming one!
    With HSERIN, I'd read that's it's best to have a 'trigger' character, followed on immdeiately by the actual data. So this is what I've done, when my PIC sees a leading 0, it takes in the folloiwing three bytes as a string. I need my 3 byte input string to be 3 actual numbers that my PIC program can act upon.
    turns_required VAR BYTE[3] ; this is the user input for how many turns of a motor
    direction_change var byte[3] ; again, user input for when the motor should change direction.
    counter var byte
    counter = 0
    pause 800 ; let things settle
    HSEROUT [13,10]
    Main
    HSERIN 5000,finish,[WAIT("0"),STR turns_required \3] ; wait for 3 bytes following the character '0;
    HSEROUT ["Number of turns will be.... ", STR turns_required \3,13,10] ' oyutput it to screen to confirm
    count_loop:
    pause 200
    GOTO count_loop
    How can I convert my three character 'input' string (which will always be numbers) into an actual number that my program can use - I guess what i need is a way of converting a string into a number? (or perhaps a way of taking the input as raw number vs the string method I'm using?)
    When I run the program, I can see the counter starts decrementing from a different number to that what I input (if for example I input 0032, the count below starts decrementing at 48, in fact it starts at 48 no matter what number I input!!)
    Mar 2009
    ok, I've kludged it...but there's *got* to be an easier way than this...
    'set up some variables....
    turns_required VAR BYTE[3] ; the main input
    UNITS VAR BYTE ' will use this to extract units from above
    TENS VAR BYTE ' will use this to extract tens from above
    HUNDREDS VAR word ' ' will use this to extract hundreds from above
    TURNS_INPUT VAR WORD ' this will be used for the final goal - a useable number!!
    pause 200 ' let things settle down a bit
    HSEROUT ["Enter Number of turns required (3 digits + leading 0)>>>", 13,10] 'prompt for input.
    Main
    HSERIN 5000,finish,[WAIT("0"),STR turns_required \3] 'read in a 3 character string preceded by a '0'
    UNITS = turns_required(2) - 48 'extract the last character (units) & revert it down to a true decimal
    TENS = (turns_required(1) - 48) * 10 'extract the middle character (tens) & revert it down to a true decimal
    HUNDREDS = (turns_required(0) - 48) * 100 ''extract the first character (tens) & revert it down to a true decimal
    TURNS_INPUT = UNITS + TENS + HUNDREDS ' add them all together.
    Using the above, I've turned my keyed in '3 character ASCII code' based string into its numeric equivalent, (that I can use later in the PIC program) ...but like I say, there's got to be an easier way?
    Apr 2009
    Boise, Id
    Instead of reading the HSERIN as STRING, read it as a DEC in to your WORD variable. Also you can use an interupt to know when you have data. If you got the interupt to work on your counter, you are close to getting it to work on data input. Darell Taylor interupts make it pretty easy. What you need is something like this at the begining:
        INCLUDE "DT_INTS-18.bas"     ; Base Interrupt System
        INCLUDE "ReEnterPBP-18.bas"     ; Include if using PBP interrupts
        INCLUDE "Elapsed_INT-18.bas"  ; Elapsed Timer Routines
                INT_Handler    TMR1_INT,  _ClockCount,   PBP,  yes
                INT_Handler    TMR0_INT,  _ToggleLED1,   PBP,  yes
                INT_Handler    RX_INT,     _Check_Command, PBP, yes
       T0CON = %10001000
    @ INT_ENABLE    TMR1_INT
    @ INT_ENABLE    TMR0_INT
    @ INT_ENABLE    RX_INT
    When the Pic recieves data it will set the RX_INT flag and jump to the _Check_Command Sub, the pic will save a some data in the UART, so you don't need to be waiting for the data to come, just need to get it when it does. The Check_Command sub looks like this:
    Check_Command:
        hserin 10,No_Cmd,[Dec In_Val]
    'Cool code goes here, I was reading single digit numbers and had
    'if statements to reply with different information, FYI calling another sub
    'in an interupt sub was breaking the code.  So be carefull jumping out
    'and expecting things to work as normal on return.
    @ INT_RETURN
    'Shouldn't make it to No_Cmd, since there was data on RX to get into
    'this sub. The Int_Return above should jump you back to your code
    'after you get your command
    No_Cmd:
        HSEROUT [10,"Made it to No_Cmd: I'm broke",10]
    'Don't know if disabling the RX_INT and enabling is needed
    'I was trying to fix the issue of calling a sub from an interupt sub
    'and thought this might help.
    @ INT_DISABLE   RX_INT
    @ INT_ENABLE RX_INT
    @ INT_RETURN
    I have seen examples of reading strings if data on a single HSERIN command, I haven't ventured that far myself, but you should find examples if you search this forum, I'm sure that's where I saw it.
    Just to summerize, I used this to read single numbers 1-9 and had if statements for the code to react to, I didn't do math, so I might just be lucky that it worked.
    Have Fun
    Shane
  1. Melabs U2 Programmer Command Line Options
    By Robert Wells in forum General
    Last Post: - 3rd July 2009, 03:11
  2. problems with USB programmer
    By malc-c in forum General
    Last Post: - 10th May 2007, 21:14
  3. USB programmer problems
    By uiucee2003 in forum USB
    Last Post: - 16th August 2006, 00:47
  4. General Programmer Questions
    By mslaney in forum General
    Last Post: - 17th December 2004, 19:16
