Alas, my existing switch setup is a simple reed switch (so I have to debounce).
I've done some googling today & think that optical is the way to go. I'll probably use this guys implementation - a CD with some black stripes drawn on it!
http://www.vk2zay.net/article/29
http://www.vk2zay.net/article/28
(but perhaps having it feed into a monostable to clean those pulses up a bit)
Firstly, it appeals to the cheapskate in me, but more importantly, I can get even finer resolution - surprisingly 36 degree resolution isn't really sufficient...I'd much rather have 10 degrees or less
Totally off topic, but here's the maths.
Let's I'm feeding 0.15mm wire onto the main motor (actually the main motor holds a steel rod in jaws, upon which the copper wire feeds onto forming a coil)
So, for every turn of the main motor, I need the stepper motor (feeding the wire onto it), to traverse by 0.15mm.
My stepper is a 7.5 deg motor (meaning it takes 48 pulses to get it to turn one full revolution). I've placed some M8 threaded rod over the stepper shaft (this has a pitch of 1.5mm)....it is via this thread that I wrap the copper wire around feeding onto the main motor, if you can't visualize this...have a look here for a similar setup about 23 seconds in...he's using *much* chunkier wire, mine is more akin to thick hair).
Therefore for every full turn of the stepper (48 pulses) the wire moves 1.5mm (this being the thread pitch). But I *need* it to move just 0.15mm for every turn of the main motor. So to get the stepper to move the wire just 0.15mm, I need to send 4.8 pulses to the stepper for every turn of the main motor - obviously, I can't send 0.8 of a pulse to the stepper! Therefore if I had more tach resolution, I'd avoid such 'rounding' errors (or as I'm doing now, having to add in extra pulses every so often to make up for the shortfall)
