Getting SERIN2 to work?
Results 1 to 12 of 12
    Delaware
    Default Correction on resistor values TX and RX
    I looked at the resistors that I used successfully. My previous post was in error with regard to the resistor value used in the TX line from the PIC. I used a 10k, not a 1k. I don't know if a 1k will work in the TX line, but I know the 10k works.
    I still use the 1k in the RX line to the PIC, though.
    I am next going to install an RS232 converter to avoid all this resistor roulette!
    Best regards to all,
    Bob
    Default Try Hserin Hserout
    Bob,
    I've used the ubiquitous MAX232 to a PC RS232 port with success in an automated tester using Hserin and Hserout. I'm jumping on on this cause I use the PIC16F876A also.
    The DB9 on this end is Female so you can use a standard male to female cable to the PC.
    Here's some syntax and I'll drop in the related schematic. I have it set at 4800 baud, but I'm sure it'll run much faster. I deleted a bunch of stuff from the diagram, but I left the ISP hookup, as well as the reset button.
    This bit of code will wait for *T from the PC, run the TECH subroutine, then after sending the A/D results, waits for 3 numbers, converts them into decimal, uses that for the PWM value, then waits for FN to go on it's way.
    The formating stuff in the HSEROUT code is to pad 0s cause the PC (running Labview) was looking for precisely 3 bytes at that point.
    DEFINE OSC 8'  		        USE 8MHZ CRYSTAL OSC.
    DEFINE ADC_BITS 10'	        +VREF= 2VDC 1 = .00195V OR ~ 2MV
    DEFINE ADC_SAMPLEUS 50'   SAMPLE TIME .1MS
    DEFINE CCP1_REG PORTC' 		Hpwm channel 1 pin port
    DEFINE CCP1_BIT 2' 		    Hpwm channel 1 pin bit
    DEFINE CCP2_REG PORTC'		Hpwm channel 2 pin port
    DEFINE CCP2_BIT 1'		    Hpwm channel 2 pin bit
    DEFINE HSER_RCSTA 90h'	Set RECIEVE Enabled
    DEFINE HSER_TXSTA 24h'	Set XMIT Enabled HS
    DEFINE HSER_BAUD 4800'		IL1700 BAUD RATE
    DEFINE HSER_CLROERR 1'		CLEAR OVER RUN ERRORS
    DEFINE CHAR_PACING 1000'	CHAR PACING(uSEC) TO 1MS
    TRISA=%00001111'	SET UP PORTA I/O (1=IN,0=OUT)
    TRISB=%11001000'	SET UP PORTB I/O
    TRISC=%10000000'	SET UP PORTC I/O
    ADCON1=%10100101'	USE PORTA.3 PIN5 AS VREF+ @ 2.0VDC
    ADCON0=%01000000'	A/D OFF -- RIGHT JUSTIFY. 6MSB=0 ADRESH
     HSERIN[WAIT("*"),BUNDONE]
            IF BUNDONE = "T" THEN GOTO TECH ' T FOR TECH
    TECH:'                  ****************  TECH ************
    BLEDOUT = 0'		          TURN BLUE LED ON
    HPWM 1, BLUELVL, 5000'		    CCP1=BLUE SET CURRENT
    ADCON0 = %01001101'	              BLUE ADC
    ADCIN 1, BLUSNS'                             READ IT
    BLEDOUT = 1'		          TURN BLUE OFF
    RLEDOUT = 0'			   TURN RED ON
    HPWM 2, REDLVL, 5000'		   CCP2 =RED SET CURRENT
    ADCON0=%01000001'		 RED A/D
    ADCIN 0, REDSNS:REDSNS=REDSNS MIN 999
    RLEDOUT = 1'			    TURN RED OFF
    'HPWM 1, 0, 5000'          STOP PWM
    'HPWM 2, 0, 5000
    IF BLUELVL <10 THEN
    HSEROUT["00",DEC BLUELVL]:GOTO RED1
    IF BLUELVL <100 THEN
    HSEROUT["0",DEC BLUELVL]:GOTO RED1
    HSEROUT [DEC BLUELVL]
    GOTO RED1
    RED1:
     IF REDLVL <10 THEN '           FORMATING
    HSEROUT["00",DEC REDLVL]:GOTO BLU1
     IF REDLVL <100 THEN
    HSEROUT["0",DEC REDLVL]:GOTO BLU1
    HSEROUT [DEC REDLVL]
    GOTO BLU1
    BLU1:
        IF BLUSNS <10 THEN
        HSEROUT["00",DEC BLUSNS]:GOTO RED2
        IF BLUSNS <100 THEN
        HSEROUT["0",DEC BLUSNS]:GOTO RED2
        HSEROUT [DEC BLUSNS]
    GOTO RED2
    RED2:
         IF REDSNS <10 THEN
        HSEROUT["00",DEC REDSNS]:GOTO WAITF
        IF REDSNS <100 THEN
        HSEROUT["0",DEC REDSNS]:GOTO WAITF
        HSEROUT [DEC REDSNS]
    GOTO WAITF
    WAITF:
    HSERIN [WAIT ("F"),EFF]
    IF EFF = "N" THEN
    GOTO BEGIN
         GOTO BLULEDSET
        GOTO TECH
    BLULEDSET:'----------------------SET BLUE--------------------------
    HSERIN [WAIT("@"),STR INCOM\3]
    INCOM[0] = (INCOM[0]-"0") '
    INCOM[1] = (INCOM[1]-"0") ' Convert to decimal
    INCOM[2] = (INCOM[2]-"0")
    X = 0 '                     RESET THE VARIABLE
    X = X + INCOM[0] * 100
    X = X + INCOM[1] * 10
    X = X + INCOM[2]
    BLUELVL = (X MIN 255)
    X = 0
        HPWM 1, BLUELVL, 5000'		   CCP1  AND SET CURRENT
    Then more of the same for the Red channel.
    I hope this helps, and I pasted everything correctly!
    Bron
    The less you expect, the more you get.
  1. GPS $GPRMC to PIC16F684. Need help with SERIN2
    Last Post: - 27th November 2009, 09:47
  2. SERIN2 digit parsing
    Last Post: - 7th January 2007, 23:15
  3. with 40 MHZ osc serin2 not work
    By Pedro Santos in forum mel PIC BASIC Pro
    Last Post: - 13th August 2006, 22:56
  4. SEROUT2 and SERIN2 commands
    By bangunprayogi in forum mel PIC BASIC Pro
    Last Post: - 4th August 2005, 09:03
  5. Pin RA4 doesn't work
    Last Post: - 15th July 2004, 12:03
