GLCD handling in PBP
Results 1 to 4 of 4
    Mar 2009
    Default GLCD handling in PBP
    Can anyone say if there will be any intention of including GLCD commands in PBP in any future updates? I expect the reason this as not included at the time the compiler was written was because GLCD modules were considered either too expensive or too esoteric for most hobbyists to use. However these modules have proliferated from Chinese manufacturers in the last few months and prices have dropped substantially. Considering that BASCOM compiler users have the luxury of support for a number of graphics displays for AVRs and 8051 mpus, the same such support for PIC users would be superb.
    Mar 2009
    San Diego, CA USA
    I've written routines for a GLCD. They are very controller dependent, ie no two are alike. The LCD command in the existing PICBasic is barely usefull to me, only if I'm "playing" with the X1 protoboard.
    I used the Shiftout command, I set up variables per the LCD mfg instructions, and then used a freeware tool to "make" the fonts. These were all stored at the end of the program with Writecode, 3.5K worth. Most GLCD's (bare) don't have fonts. To encode that into PICBasic would be difficult and only possible on the chips with larger (8K) memory. Then people wouldn't like those fonts or that controller, etc. Not worth the engineering time in my opinion. Also, it is easier for YOU to do it than you think.
    Also, many LCDs are now serial. So all that is built into the module, again the routines are different for each mfg. It would be like requesting a command for every I2C chip on the market, just too many.
    And then you might find that the command is too bloated. I don't use HPWM anymore because it adds dozens of lines and computations to a simple process (once you learn it). Same for ADCIN, BUTTON, TOGGLE, and a few others. I don't mean that I use assembly. Set the CCPCON registers, done in 6 lines.
    Mar 2009
    Smile
    Thanks for that Greg. I was just curious since I might want to explore the option of using one in a multi-PWM LED controller project. A 4x20 LCD module that has RGB LED backlighting would be lovely. To date I believe Crystalfonz sells a GLCD module with RGB backlight but not a character display (yet). Since my project involves between 10 and 100+ PWM controlled RGB channels, needless to say the more feedback the user has with regard to setting the various colour programs, the better!
    Feb 2003
    Sydney, Australia
    Checkout http://www.circuit-ed.com/index.aspx - they have a graphic LCD with RGB backlight for $36us.
    I have used it with MikroE basic and it works well (other than missing all the non-GLCD commands I was used to in PBP...)
    bill.
  1. PBP Book
    By Bruce in forum Off Topic
    Last Post: - 4th October 2021, 13:55
  2. GLCD Library for PBP
    By octal in forum mel PIC BASIC Pro
    Last Post: - 7th November 2008, 16:21
  3. PBP Glcd
    By RICHARD.C in forum mel PIC BASIC Pro
    Last Post: - 13th June 2008, 03:21
  4. Compiler differences between PBP 2.33 & 2.46
    Last Post: - 2nd May 2006, 20:01
  5. Newby- PBP wont compile for 18F (MPLAB)
    Last Post: - 18th December 2005, 00:30
