Pic 16 F628A not working
Results 1 to 7 of 7
    Mar 2006
    Ankara -Turkey
    Default F628
    Thanks for your interest.
    F628 REALLY not working .
    I use f84 on same board but when ı put F628 NOTTİNG HAPPEN. I can not see any charecter on LCD. or any output from pic.
    I think pic not recoc. Oscilator. Maybe ı do same mistake when ı write the code. Is there a way that ı declare to pic that use external xtal oscilator 20 MHz.
    Thanks.
    Birbirimize yardım için buradayız.
    We are here to help each other....
    Wink One good reason ...
    Hi, Turkouaz
    there's a major difference in the PortA inputs ...
    TTL for 16F84a ...
    Schmitt Trigger for 16F628a ...
    soooo, I'd recommend you to check your input levels on PortA
    THE solution for this problem is to use a 16F87/88 ...
    PS: code lines are never too much to show : anything you have to hide ???
    Mar 2006
    Ankara -Turkey
    Default F628
    Thanks ACTRONICS.
    But I do not use any A port.
    But I want to use F628 because ı can use SMD F628 in my board.
    Mar 2006
    Ankara -Turkey
    Default F628
    I fond the problem myself.
    In defoult in f628 .inc files osc is XT osc. I changed it to HS_OSC the problem has gone.
    Thanks everyone.
  1. Pic 16 F628A pulsein Problem
    By turkuaz in forum mel PIC BASIC Pro
    Last Post: - 27th February 2009, 11:46
  2. Replies: 16
    Last Post: - 3rd November 2008, 20:58
  3. Midi, Interrupts and Pic better than SX28?
    By Lajko in forum mel PIC BASIC Pro
    Last Post: - 27th September 2008, 01:26
  4. Stop the pic working
    By sgufa in forum mel PIC BASIC Pro
    Last Post: - 9th July 2007, 01:38
