Pic 16 F628A not working
Results 1 to 7 of 7
    Mar 2006
    Ankara -Turkey
    Default Pic 16 F628A not working
    Hi.Frends.
    I want to use F84 but in my Country ı can not find F84 SMD. So I decide F28 to use becouse ı can find F628 SMD easly.
    But ı have a problem with f628 as follows:
    I wrote the for F84 and I did necessery changing for F628 but code not working on F628.
    Code sample for F628:
    CMCON=7
    VRCON=0
    But it is not vorking. then:
    CMCON =7
    Not working.
    Is there another way to need chamge or what Iam doing wronge.
    If anybody helpme thanks alot!....
    Birbirimize yardım için buradayız.
    We are here to help each other....
    Aug 2008
    Can you explain what you meant by not working? is it cannot read the input, set the output, compilation error etc?
    Feb 2008
    merhaba. Do you have a pullup resistor on pin a5/mclr?
    That was often the reason why my progs didn't seem to work.
    But beware: If you use ICSP you have to combine the resistor with a diode to prevent your circuits from the +12V of the programmer!
    Mar 2006
    Ankara -Turkey
    Default F628
    Thanks for your interest.
    F628 REALLY not working .
    I use f84 on same board but when ı put F628 NOTTİNG HAPPEN. I can not see any charecter on LCD. or any output from pic.
    I think pic not recoc. Oscilator. Maybe ı do same mistake when ı write the code. Is there a way that ı declare to pic that use external xtal oscilator 20 MHz.
    Thanks.
    Wink One good reason ...
    Hi, Turkouaz
    there's a major difference in the PortA inputs ...
    TTL for 16F84a ...
    Schmitt Trigger for 16F628a ...
    soooo, I'd recommend you to check your input levels on PortA
    THE solution for this problem is to use a 16F87/88 ...
    PS: code lines are never too much to show : anything you have to hide ???
    Mar 2006
    Ankara -Turkey
    Default F628
    Thanks ACTRONICS.
    But I do not use any A port.
    But I want to use F628 because ı can use SMD F628 in my board.
    Mar 2006
    Ankara -Turkey
    Default F628
    I fond the problem myself.
    In defoult in f628 .inc files osc is XT osc. I changed it to HS_OSC the problem has gone.
    Thanks everyone.
  1. Pic 16 F628A pulsein Problem
    By turkuaz in forum mel PIC BASIC Pro
    Last Post: - 27th February 2009, 10:46
  2. Replies: 16
    Last Post: - 3rd November 2008, 19:58
  3. Midi, Interrupts and Pic better than SX28?
    By Lajko in forum mel PIC BASIC Pro
    Last Post: - 27th September 2008, 00:26
  4. Stop the pic working
    By sgufa in forum mel PIC BASIC Pro
    Last Post: - 9th July 2007, 00:38
