Bit masking rules
Results 1 to 3 of 3
    Jun 2005
    Up the bush, Western Plains, NSW Au
    Default Bit masking rules
    I have not done any masking of bits for some 30 years, and it seems to me that the masking rules have changed in PBP?
    My memory of this is : to mask off the high nibble of a byte, the unwanted nibble would be ANDed with "0"s and the wanted nibble would be ANDed with "1"s IE %01100101 AND %00001111 would = %00000101 that is the high nibble would be ignored while the lower nibble would be effectively unchanged. However, the way I read the manual the operation is oposite.
    indata = %01011011
    debug "raw data ",bin8 indata," "
    outdata = indata and %11110000
    indata = indata and %00001111
    debug "indata ",bin8 indata," "
    debug "outdata ",bin8 outdata
    .....Is what I have been playing around with, but the first byte comes out correct (No modification so it should) Both the next two results come out as % 11111111
    This seems to be way out of kilter with my memory of ANDing stuff with real logic gates (remember them?)
    Once again I figure I'm doing something wrong, but damned if I can figure out what.
    I have some stuff feeding the lower 4 bits of porta and i want to mask off the higher bits so I can come up with a straight HEX digit, but it don't appear to be working. Dammit!!
    If I don't mask anything and simply debug hex1 indata it is OK, but using the whole byte is not useful as the other bits are also active with other stuff that I don't want at the time.
    Another night of frustration coming up, I see.
    Thanks in advance for any pointers folks.
    Peter Moritz.
    New South Wales,
    Australia.
    California, USA
    Well, I'm a serious newbie myself, but I *think* you need to use the Bitwise Operator "&", not the logical operator "AND".
    Try:
    outdata = indata & %11110000
    Edit: yeah, I just checked pgs 39 and 40 of the PBP manual (printed version) and it describes the difference between "&" and "AND". You definitely want "&".
    steve
    Jun 2005
    Well I did warn you it would be somthing bloody simple.
    Spot on.
    Thanks heaps.
    Now for some sleep!!
    Peter Moritz.
    New South Wales,
    Australia.
    Last Post: - 14th June 2016, 07:55
  2. Doubt with interrupt on change
    By lugo.p in forum mel PIC BASIC Pro
    Last Post: - 5th March 2010, 15:22
  3. Sleep Mode
    By Pesticida in forum mel PIC BASIC Pro
    Last Post: - 13th March 2008, 10:31
  4. PICBasic newbie problem
    Last Post: - 12th February 2008, 00:55
    Last Post: - 6th March 2005, 01:07
