Variable organization
Results 1 to 12 of 12
    I saw the problem mainly in large code with interrupts. If one wants to use a variable inside the interrupt, this must be new. But, if for every task we assign a new variable, at the end we may have a lots that are really not necessary and most of them used once.
    This is new to me - I've not come across this anomally/limitation/requirement before.
    I write code in a very structured way... it doesn't mean it's the RIGHT way, it just happens to work for me.
    1. At the very top I have the PIC Definitions/Configurations
    2. Next I have all the Hardware Assignments and Pin Definitions, LCD and all other Defines.
    3. Then EEPROM Data Statements
    4. Then RAM Definitions
    5. Then Constant Definitions
    6. Here sits a jump to step 10.
    7. Assembler Routines
    8. Interrupt Routines
    9. Subroutines
    10. Hardware and Register Initialisation sequences
    11. Main Program Loop
    Wherever possible, Variables, Definitions, Subroutines etc are all in Alphabetical order within their own sections (makes them easy to find subsequently).
    The variables (for example at step 4) are all in one spot... if I need Bits, then I define a Byte or a Word and sub-define that into bits.... variables that are used and reused many times throughout the program (like intermediate working variables) are defined to sit in Bank0 (it makes for considerably smaller code)...
    Here is a typical example of (a few) variable definitions in a (large) program...
    	SystemError var Byte Bank0			' Hardware Fatal Error Flags
    		Tamper var SystemError.0		' 	Main CPU Anti-Tamper
    		I2CError var SystemError.1		' 	I2C Bus Failure
    		I2CVersion var SystemError.2		' 	EEPROM Incompatible
    		I2CTimeout var SystemError.3		' 	I2C Bus Timeout
    		I2CDevFail var SystemError.4		' 	I2C Device Failure
    							' 	SystemError.5 - Unused - Reserved
    							' 	SystemError.6 - Unused - Reserved
    							' 	SystemError.7 - Unused - Reserved
    	SystemFlags var Byte 				' System Operational Flags
    							'	0=Unused
    							' 	1=Unused
    							'	2=Unused
    							'	3=Unused
    		UECursor var SystemFlags.4		'	4=User-Entry Field Cursor (0=Invisible, 1=Visible)
    		UEEntry var SystemFlags.5		'	5=User-Entry (0=NOT Permitted, 1=Permitted)
    		UESecure var SystemFlags.6		'	6=User-Entry Security (0=Unsecure 1=Secure)
    							' 	7=Unused
    	TempA var Byte					' Temporary Storage Variable
    		TempBitA var TempA.0			' 	Just a Temporary Bit
    	UEData var Byte	Bank0				' User-Entry EEPROM Data to be Loaded
    	UEDataReference var Byte			' User-Entry EEPROM Data Reference
    	UEDisplay var Byte				' User-Entry EEPROM Data being Referenced
    	UELen var Byte					' User-Entry Field Length (0-16 chars long)
    	UEMax var Byte					' User-Entry Maximum Field Entry Value
    	UEMin var Byte					' User-Entry Minimum Field Entry Value
    	UEPos var Byte					' User-Entry Current Position in Field (0-15)
    	UEReference var Byte				' User-Entry Display Reference Pointer
    	UETemp var Byte					' User-Entry Temporary Counter
    	UETimeOut var Byte Bank0			' User-Entry Keyboard TimeOut Counter
    	UEType var Byte	Bank0				' User-Entry Field Type
    						  	'	 0=Alphanumeric
    							'	 1=LCD Contrast Setting
    							'	 2=LCD BackLight Setting
    							'	 3=Idiot Selection (eg Yes/No)
    							'	 4=Idiot Selection with Reset (eg Hours Counters)
    							'	 5=Idiot Selection with Erase (eg Erase Event Log)
    							'	 6=Date & Time Entry & Validation
    							'	 7=Option Selecting Off/On/Auto Modes
    							'	10=Numeric (0-255) c/w leading Blank Suppression
    							'	11=Numeric (0.0-25.5) c/w leading Blank Suppression
    							' 	2x=Option with Menu Skip (preset to x)
    							' 	3x=Option with individual x-Bit manipulation
    	XDataAddress var Word Bank0			' External EEPROM 16-bit Address
    As you can see, there's noting clever here - it's just all arranged logically, all placed in one section, all documented and done to be easilly maintained.
    Hi Melanie.
    Well, I suppose that most people will without much thinking follow in general that structure too.
    But what I tried to express with my limited english was this:
    Say you have a long program with many variable, some of them common to most routines like the CounterA, CounterB etc. As these are used for counting purposes, they are present in many subroutines and For-Next loops.
    Lets suppose now that an interrupt occurs in the middle of a subroutine and a counter variable is necessary for the interrupt itself.
    We need now a new variable, exclusively for this iterrupt,used only once.
    If accidentally one uses the, say, CounterA variable,which is at this particular time used in a subroutine, sure the program will go to the La-La-Land!
    I feel a little Skroutz with the blind use of variables.
    Duhhhh.... Yes, I use CounterA, CounterB... DataA, DataB in my subroutines, but INTERRUPTS by their very nature will INTERRUPT the flow of things, so you wouldn't use the same variables within those routines unless the interrupt is supposed to change the way the main program works - I would have thought that was obvious!
    In the same way, if you nest subroutines within subroutines for a particular task... you can't have the same variables in each of those subroutines as they'll mess with each other.
    It doesn't mean that every subroutine has to have it's own exclusive variables, but you do need to keep track of what is being used where - and to that end, when you list your subroutine, have a header which simply reminds you what's used inside it...
    	'	Subroutine Displays Message on LCD from Program CodeSpace
    		' CounterA - General Byte Variable
    		' CounterC - General Word Variable
    		' DataA - General Byte variable
    		' Message - ID of Message to Display
    		' MessageLen - Number of characters to Output
    		' MessageSupport - Beginning of Message Table in Codespace
    		' XDataAddress - 16-bit Address in Codespace
    DisplayExternal:
    	@ GetAddress _MessageSupport, _XDataAddress	' Get Start address of Message Support Table
    	XDataAddress=XDataAddress+(Message*18)
    	ReadCode XDataAddress,MessageLen
    	XDataAddress=XDataAddress+1
    	ReadCode XDataAddress,DataA
    	If DataA>0 then LCDOut $FE,DataA
    	If MessageLen>0 then
    		For CounterA=1 to MessageLen
    			CounterC=XDataAddress+CounterA
    			ReadCode CounterC,DataA
    			LCDOut DataA
    			Next CounterA
    Wink
    Hi, Ioannis
    I believe PBP Variables are GLOBAL Variables ... and You'd better turn to "C" if you want LOCAL variables.
    or "another Basiç " ... Booooooooooooooo.
    Identifier is declared in the function or procedure Scope extends from the point where it is declared to the end of the current routine. These identifiers are referred to as locals.
    Now, let's say I do not understand clearly what you mean ...
    You simply could add a memo to the variable name like "Count_inter" or " Count_LCD "for your example ...
    I do not think RAM is THE problem ... as you have to preserve the "eventually overwritten" Variables !!!
    BTW ... I didn't find the Max. Variable Length in the Holy Manual ... ( 32 Characters ??? )
    PS: Tell me You won't implement a " Variable Stack " ... tell me you won't ... lol
    Actually, I assumed the maximum variable length to be 65534 bytes (though I've never gone beyond about 8k personally - after all you gotta leave some space for your actual program too!!!)...
    Word variable minus 2 (because you can't have 65536) and it has to be an even number because the way 18F parts store stuff in Program Codespace.
    Talking
    Hi, Mel ..
    I meant the Max Variable NAME length ....
    No, not yet Alain. I think Darrel did this a while back?
    As for the C i do not feel very comfort... That += and =- get me on my nerves!
    Melanie:
    I usually name the variable in a way that is obvious as to what they are doing. But I don't like the CounterA, B, C, D, ... Z variables all to be used for the same task in different places. But I see no other way as the meaning of Local in PBP is not defined.
    Thanks for the talking.
    If you're writing large complex programs, then your chosen PIC probably has so much RAM you're never going to use it all anyway... so why not have a dedicated set of variables for every subroutine and ISR... after all, that's what C does with it's local declarations.
  1. EEPROM Variables (EE_Vars.pbp)
    Last Post: - 26th October 2012, 01:06
  2. Variable PWM PIC18F2431
    By trr1985 in forum mel PIC BASIC Pro
    Last Post: - 12th June 2009, 07:03
  3. Help with sound command in 2 programs
    Last Post: - 5th July 2007, 21:36
  4. WORD vs BYTE variable lengths
    By bartman in forum General
    Last Post: - 28th November 2005, 22:16
  5. Storing a variable in EEPROM
    Last Post: - 29th October 2005, 14:53
