16F84/16F628 and Manchester
Results 1 to 8 of 8
    Aug 2007
    Mississauga, Ontario, Canada
    Default 16F84/16F628 and Manchester
    Hi all...
    OK, OK... I realize that the Manchester topic has been beaten to death here. I promise you that I've read pretty much every post on it but I still have questions and I hope some of you will steer me in the right direction.
    Here is the deal: I'm trying to design a wireless link between two PIC devices using a 433 MHz RF module. Device1 will be sending information such as temperature, garage door status, garage lights status, etc, to Device2.
    Initially I was going to make life simple and modulate the RF TX by a PIC serial port and send out your typical ASCII type data, but then I stumbled across some information on the benefits of Manchester coding and decided to go with that instead.
    Since I have an abundance of 16F84 and 16F628 chips, I'd prefer to concentrate on those as much as possible.
    Here are some of the questions that linger:
    1. I've noticed some examples here make use of HSEROUT/HSERIN commands. I tried writing the code using these and the program (Microcode Studio with PBP) would not compile it. Subbing these commands for SEROUT/SERIN eliminated these problems. I'm assuming my chips do not support these commands. Am I correct?
    2. OK...old school thinking here. Since each Manchester data word is 16 bits long.... how do I send it out of the PIC that has a start, 8 data byta, stop , parity bits? Some examples here were using SEROUT2 as opposed to SEROUT command and I did some research on those in the Microcode Help file. Am I correct in assuming that SEROUT2 allows to transmit longer data and is not limited to just 8 bits?
    3. I understand that one needs to send out a preamble allowing the receiver to stabilize before it accepts good data. Does the preamble need to be sent out before every data word, or just at the beginning of the entire data sequence?
    If the latter, how does the receiver distinguish between each data word, other than couting the incoming bits? Would it be wise to insert some sort of a control character in front of each data word so the receiver has better time separating one data word from the next?
    I think this is it for now. I'm sure there will be more questions but these three should be enough to get me started.
    Any help would be greatly appreciated.
    Thanks!
    Alex
    Quote Originally Posted by Navaidstech View Post
    Seems not...
    Correct. Have you read the chips data sheets???
    No. You still send bytes but every data byte is encoded in two Manchester bytes.
    Only at the start of the data sequence.
    Aug 2007
    Obviously I missed a few posts.
    Thanks for the info there Ioannis.
    I searched the forum some more this morning and I was able to whip out a tx/rx pair that ALMOST works, based on code tidbits I found..
    At the moment the two modules are connected with wires but once I get the code rectified a bit, I'll move up to RF modules.
    I say "ALMOST" because the tx part seems to be working ok, however the receiver isn't quite there yet.
    Here is the code that I'm using for transmitting (I have observed it on the oscilloscope and it appears to be working):
    dataport var PORTB.0
    START:
    serout2 PORTB.0,813,[$55, $55, $55, $AA]
    mydata = "T"
    dataport = $00
    goto start
    ENCODEMANCHESTER:
    ManchesterWord=0
    For CounterA=0 to 7
    If MyData.0=0 then
    ManchesterWord.14=1
    ManchesterWord.15=1
    If CounterA<7 then ManchesterWord=ManchesterWord>>2
    MyData=MyData>>1
    Next CounterA
    serout2 dataport,396,[manchesterword.lowbyte, manchesterword.highbyte]
    And here is the receiver code:
    RECEPTION var PORTB.0
    INFO VAR PORTB.2
    ERROR var PORTB.1
    START:
    manchesterword=0
    SERIN2 reception, 813, [WAIT($AA),ManchesterWord.LowByte,ManchesterWord.Hi ghByte]
    gosub ManchesterDecode
    goto start
    ManchesterDecode:
    ErrorFlag=0
    For CounterA=0 to 7
    If ManchesterWord.1=0 then
    MyData.7=0
    ERROR = 0
    If ManchesterWord.0=0 then
    ErrorFlag=1
    ERROR = 1
    MyData.7=1
    ERROR = 0
    If ManchesterWord.0=1 then
    ErrorFlag=1
    ERROR = 1
    If CounterA<7 then MyData=MyData>>1
    NEXT COUNTERA
    serout2 info, 813, [Mydata]
    I set PORTB.1 as an indicator telling me whether or not the Manchester code has errors in it... I was monitoring that pin with a scope and not once did it light up, yet I'm getting garbage coming out on pin 2.
    Somehow I'm thinking that the receiver code is missing something but I'm hoping if you guys could point out where the problem lies.
    thanks
    Alex
    I cannot see how these two pieces of code (tx and rx) can work together.
    Read your code again,or post the working code.
    Or try the untested one that is attached.
    Rename to .bas and burn it.
    Aug 2007
    Of course!
    I'm sending the preamble at a wrong baud rate! DOH!
    Changed it and it works ok now....
    thanks!!!
    Alex
    Aug 2007
    Ioannis...
    looks like I jumped the gun there. Your code seems to be working much better than the one I used.
    Thank you for your help. Hopefully I'll be ok from hereon.
    Alex
    ...looks like I jumped the gun there...
    ? I am not sure i follow...
    You are welcome!
    Aug 2007
    In my previous message I indicated that once the baud rate was changed, the original program that I posted was working ok.
    Then I noticed some errors popping up so I decided to delve further into the program... it didn't look right so I decided to use your untested routines and they worked great.
    Thanks again!
  1. Manchester coding/decoding Code help
    By financecatalyst in forum Code Examples
    Last Post: - 25th August 2009, 19:05
  2. Reading in Manchester code
    By brid0030 in forum Code Examples
    Last Post: - 10th March 2009, 21:55
  3. SERIN2 – SEROUT2 and Manchester mistake.
    By RCtech in forum Serial
    Last Post: - 4th September 2007, 22:55
  4. Help with serin, serout, Manchester encoding
    Last Post: - 5th April 2007, 13:31
  5. Manchester and baud [II]
    By mbw123 in forum mel PIC BASIC Pro
    Last Post: - 23rd December 2006, 22:35
