500K or less triggering of a pin.
Results 1 to 8 of 8
Threaded View
  1. #7
    California, USA
    Oh Guys, stop struggling....
    10K between the PIC pin and 0v. Your 500K between the pic in and +5v. Use an ADC pin. If your device is subject to noise pick-up, then put a 100nF across the 10K. That's it.
    Calibration. Take an ADC reading with a Resistor at 500k. This is your minimum 'threshold'. Take another ADC reading with a Resistor at say 450k. This is your max threshold.
    You now have two values... at which point you decide to signal your 'event' condition between thos two points is up to you. You may have to use 10-bit ADC as the values will be pretty tight and 8-bit won't give you much leeway.
    I was going to suggest using a PIC with ADC, but I thought that the ADC's needed a fairly low source impedance to drive them...
    From the 16F727 data, 9.3 A/D Acquisition Requirements,
    "The maximum recommended impedance for analog sources is 10 kΩ."
    Is this not true for most of the PICs?
    Some of the PICs have analog voltage comparators don't they? Perhaps they'd be better suited to the voltage divider with 500K resistor? I guess I don't know what the input impedance is on those voltage comparator inputs.
  1. Is this a K Type sensor?
    Last Post: - 21st November 2009, 14:55
  2. DS1820 with 16f688
    Last Post: - 23rd May 2009, 06:07
    Last Post: - 13th December 2008, 18:11
  5. Another RTC, DS1287
    Last Post: - 12th December 2006, 18:07
