Is this a K Type sensor?
Results 1 to 21 of 21
    jessey's Avatar
    jessey Guest
    Quote Originally Posted by Byte_Butcher View Post
    The MAX6675 doesn't need a ADC to interface with a PIC.
    You just shiftin the serial data and it reads pretty much directly in degrees C on an LCD without too much else.
    This is pretty much all the code involved...
    'Alias pins - MAX6675 temp sensor
    MXSCLK  var     PORTB.5   'Clock
    MXCS     var     PORTB.4    'Chip Select
    MXSO     Var     PORTB.3   'Serial out
     'Allocate MAX6875 Variables
    MXTemp   var     word    'raw data from 6675/type K sensor
    TempC   var     word    'converted to degrees C
    '-----------Read and display temperature from MAX6675-----------
    MXCS = 0  'Chip select low
    shiftin MXSO, MXSCLK, 0, [MXTemp\16]   'read the data to MXTemp
    MXCS = 1    'Chip select high
    TempC = MXtemp >> 5   'right shift the data 5 places to get degrees C (Read the Data sheet)
    LCDOUT $fe,2,"Temp = ", DEC TempC, "degrees C "  ' Spit it out on an LCD
    Works for me...
    Hi Steve,
    I finally received 2 of each MAX6675's and AD595's and thought I'd use one of the 6675's first to try out your code. I found this article: http://emesystems.com/OL2therm.htm that shows a schematics for the 6675 and I have a couple of questions for you.
    This article shows 200 ohm resistors on pins 5, 6 and 7 to the microprocessor for input protection which sounds like a good idea but are not shown in the data sheet. Do you think they could cause any problems in reading the higher temperatures?
    Also in the same article the author dismisses grounding pin 2 as shown in the datasheet and I was wondering what you think of that?
    Now that I have my pickit2 programmer working good on my laptop, I'll take a breadboard to my friends place next week sometime to try your code. Once again thanks for posting your code.
    jessey
    California, USA
    Jessey,
    I didn't use any series resistors on my MAX6675, but it's probably a good idea to use them. It shouldn't cause any accuracy problems... it's all serial data, not analog signals.
    I grounded pin 2 on mine. If it's grounded, then the MAX6675 can tell when there's an open probe. (type K probes almost always fail "open") The data sheet explains it.
    Have fun!
    jessey's Avatar
    jessey Guest
    Default finally got around to it
    Hi Steve,
    It took some time but I finally got around to trying to get the sensor up and running but I'm not having any success. I'm pretty sure I have everything configured ok with your code. Could you please have a look and see if there's something that you can see that I've done wrong here? Any help from anyone would be very much appreciated. I included the schematics I used in an attachment here.
    jessey
    '* Name    : Furnace Temperature Probe                                    *
    '* Author  : Jessey Montgomery                                            *
    '* Includes: Byte_Butchers code to read temperature using a MAX6675       *
    '* Date    : April 24/th 2009                                             *
    '* Version : Using PicBasic Pro Ver 2.50, MPASM Ver 5.20, Using MicroCode *
    '*         : Studio 3.0.0.5, PICkit 2 programmer - Application Version    *
    '*         : 2.50.02 - Device File Version 1.5100 - OS Firmware Version   *
    '*         : 2.30.01. Using a Pic16F688-I/P 04470AY.                      *
    '(1) Comments & Objectives
    ' this program is used to display the temperature from a K type sensor using a
    ' MAX6675 interface...
    'Connections for the PICKIT 2 Programmer for a 16F688
    'Pickit 2 pins                   16f688 pins
    '     1 ...... Connect to ...... pin 4       RA3/MCLR/VPP
    '     2 ...... Connect to ...... pin 1       VDD (positive)
    '     3 ...... Connect to ...... pin 14      VSS (ground)
    '     4 ...... Connect to ...... pin 13      RA0/AN0/C1IN+/ICSPDAT/ULPWU
    '     5 ...... Connect to ...... pin 12      RA1/AN1/C1IN-/VREF/ICSPCLK
    '     6......................................no connection
    '*Note
    'Put a 0.1mf capicator on pin 1 of 16f688 to ground
    '                               |   16f688   |
    '                   VDD+ (--->) |1         14| (<---) VSS-
    '   RA5/TICKI/OSC1/CLKIN (<-->) |2         13| (<-->) RA0/AN0/C1IN+/ICSPDAT/ULPWU
    'RA4/AN3/TIG/OSC2/CLKOUT (<-->) |3         12| (<-->) RA1/AN1/C1IN-/Vref/ICSPCLK
    '            RA3/MCLR/Vpp(--->) |4         11| (<-->) RA2/AN2/TOCKI/INT/C1OUT
    '              RC5/RX/DX (<-->) |5         10| (<-->) RC0/AN4/C2IN+
    '        RC4/C2OUT/TX/CX (<-->) |6          9| (<-->) RC1/AN5/C2IN-
    '                RC3/AN7 (<-->) |7          8| (<-->) RC2/AN6
    '                            Configuration Of Pins
    '                                |  16f688  |
    '                           VDD+ |1       14| VSS-
    '                       Not Used |2       13| Clock output for 6675 to pin 5
    '                       Not Used |3       12| Chip Select output for 6675 pin 6
    '                       Not Used |4       11| Serial input from 6675 to pin 7
    '  Blue/White.........Enable bit |5       10| Data bit 4...............Blue
    '  Orange/Black..Register select |6        9| Data bit 5..............White
    '  Orange.............Data bit 7 |7        8| Data bit 6..............Green
    '                               |  MAX6675   |
    '                        -5 VSS |1          8| No Connection
    '          T- Alumel Lead (Red) |2          7| Serial Output to 688 pin 11
    '       T+ Chromel Lead (yellow)|3          6| Chip Select input to 688 pin 12
    '                        +5 VDD |4          5| Serial Clock in from 688 pin 13
    '(2) PIC Config Fuse Definitions for 16f688
     @ __config _INTRC_OSC_NOCLKOUT & _WDT_ON & _MCLRE_OFF & _CP_OFF & _BOD_ON
     @ ERRORLEVEL -306; ' turns off cross page boundary message alerts after compile
    '(3) PIC Hardware Definitions (ie Pin-Out & Port Assignments)
     DEFINE LCD_RSREG PORTC' LCD Register Select Port
     DEFINE LCD_RSBIT 4    ' LCD Register Select
     DEFINE LCD_EREG PORTC ' LCD Enable Port
     DEFINE LCD_EBIT 5     ' LCD Enable
     DEFINE LCD_DREG PORTC ' LCD Data Port
     DEFINE LCD_DBIT 0     ' LCD data starting bit 0 or 4
    '------------- Clear Each Port Before Setting The TRIS Registers --------------'
     Clear   ' Set all ram registers to zero
     PORTA = 0
     PORTC = 0
    '--------------------------- VSS VDD MCLR Ect. Pins ---------------------------'
    'VDD +       '(pin 1)
    'VSS -       '(pin 14)
     '------------------- SET THE TRIS  ------------------'
     '-------------------- PORTA PINS --------------------'
     TRISA.0 = 0 '(pin 13) ...................................... MXSCLK VAR PORTA.0
     TRISA.1 = 0 '(pin 12) .........................................MXCS VAR PORTA.1
     TRISA.2 = 1 '(pin 11) .........................................MXSO VAR PORTA.2
     TRISA.3 = 1 '(pin 4)  ............... NOT USED VAR PORTA.3
     TRISA.4 = 1 '(pin 3)  ............... NOT USED VAR PORTA.4
     TRISA.5 = 1 '(pin 2)  ............... NOT USED VAR PORTA.5
     '-------------------- PORTC PINS --------------------'
     TRISC.0 = 0 '(pin 10) Blue........... Lcd Data bit 4
     TRISC.1 = 0 '(pin 9)  White.......... Lcd Data bit 5
     TRISC.2 = 0 '(pin 8)  Green.......... Lcd Data bit 6
     TRISC.3 = 0 '(pin 7)  Orange......... Lcd Data bit 7
     TRISC.4 = 0 '(pin 6)  Orange/Black... Lcd Register select
     TRISC.5 = 0 '(pin 5)  Blue/White..... Lcd Enable bit
     ANSEL = %00000000  ' set all adc pins to digital
     CMCON0 = 7         ' turn off comparators
     MXSCLK   var     PORTA.0   'pin 13 of 16f688 (Clock) to pin 5 of MAX6675
     MXCS     var     PORTA.1   'pin 12 of 16f688 (Chip Select) to pin 6 of MAX6675
     MXSO     Var     PORTA.2   'pin 11 of 16f688 (Serial) to pin 7 of MAX6675
     a VAR BIT ' a always equals zero, used in IF-THEN's instead of using GOTO's
     a = 0
     INCLUDE "modedefs.bas"
    '5. Actual Program Start (usually a "Goto MainLoop" jump)
     Pause 1000 ' Pause for LCD to initialize
        LCDOut $fe, 1, "Temp 6675 Laptop"
    PAUSE 2500
     IF a = 0 THEN MainLoop
    MainLoop:
    TempC = MXtemp >> 5'right shift data 5 places to get degrees C (in data sheet)
    LCDOut $fe, 1,"Temp = ", DEC TempC, " C  "  'Spit it out on an LCD
    PAUSE 100                                   'reduce lcd flicker
    IF a = 0 THEN MainLoop ' a always equals zero, use instead of GOTO...
    Default Very timely thread! Can I also ask about the wiring?
    I'm trying to do a similar thing just now with the MAX6675 and the breakout board from Sparkfun (at least I think it's the MAX6675, I'm at work now). It's not clear to me if the wires from the female thermocouple socket to the MAX6675 breakout also need to be K type or is copper OK? At what point is it OK to switch to copper? Could the thermocouple lead be soldered right to the breakout board for prototyping?
    Thanks for your help. Sorry if I should be starting a new thread.
    DD.
    Anyplace the wire material changes you need a reference temperature and calcs. A couple exceptions here and there though.
    May 2005
    Ne ohio
    I'm writing some code for this device also. I'm wondering why the shift of 5 places to the right when in the data sheet it looks like only 3 shifts right should put the Temperatures lsb in the correct location.
    At least that's how my initial coding is. I'll try it tonight.
    I also use MSBPOST=2 :
    Get6675_Raw:
    LOW NCS:PAUSEUS 1
    Shiftin SO, SCK, MSBPOST, [raw1\16] ' Read 16 bit temperature register
    raw1 = raw1>>3
    HIGH NCS
    Brian
    May 2005
    Ne ohio
    OK so I tried the code. Now I see you guys are right with the 5 bit shift.
    The device is capable of 12bits or 0.25 deg resolution if shifted only 3 times.
    Brian
  1. Need a cheap touch sensor idea.. here it is
    By mister_e in forum Code Examples
    Last Post: - 16th April 2016, 22:42
  2. Ultrasonic distance sensor with PIC16F84A
    Last Post: - 29th June 2009, 09:01
  3. PICBASIC PRO-coding for wireless sensor node
    By syazila in forum mel PIC BASIC Pro
    Last Post: - 10th February 2009, 00:05
  4. Replies: 6
    Last Post: - 18th January 2008, 08:17
  5. RH/Temp Sensor Example Code
    Last Post: - 15th June 2006, 15:55
