The MAX6675 doesn't need a ADC to interface with a PIC.
You just shiftin the serial data and it reads pretty much directly in degrees C on an LCD without too much else.
This is pretty much all the code involved...
'Alias pins - MAX6675 temp sensor
MXSCLK var PORTB.5 'Clock
MXCS var PORTB.4 'Chip Select
MXSO Var PORTB.3 'Serial out
'Allocate MAX6875 Variables
MXTemp var word 'raw data from 6675/type K sensor
TempC var word 'converted to degrees C
'-----------Read and display temperature from MAX6675-----------
MXCS = 0 'Chip select low
shiftin MXSO, MXSCLK, 0, [MXTemp\16] 'read the data to MXTemp
MXCS = 1 'Chip select high
TempC = MXtemp >> 5 'right shift the data 5 places to get degrees C (Read the Data sheet)
LCDOUT $fe,2,"Temp = ", DEC TempC, "degrees C " ' Spit it out on an LCD
Works for me...
