The INCLUDE file now compiles fine, but trying to compile the "Main" program causes the "Unable to open INCLUDE file NUM TEST.BAS" error. Both of the files shown below are located in c:\Program Files\Mecanique\MCS.
This is "936 include test2" file:
Pause 1000 ;for ICSP
@ __config _WDT_OFF & _CP_OFF & _PWRTE_ON & _MCLRE_ON & _INTRC_OSC_NOCLKOUT
OPTION_REG = %01000000 ;PORTB pullups enabled, no prescale
INCLUde "num test.bas"
ANSEL = 0 ;all pins digital
CMCON0 = 7 ;comparators off
ADCON0 = 0 ;ADC's off
WDTCON = 0 ;WDT off
TRISA = %00000000
TRISB = %11000001 ;switches on RB6,RB7, INT on RB0
TRISC = %00000000 ;LED on RC5, LCD bias on RC3
TRISD = %00000000
TRISE = %00001000 ;MCLR on RE3
TRISF = %00000000
TRISG = %000000
OSCCON = %01100001 ;4 mhz. internal
LCDPS = %00000000 ;Type-A,1/3 bias,no prescale
LCDCON = %01010011 ;disabled,sleep disabled,VLCD disabled,LFINTOSC,
;1/4 mux
;PIR2.4 = 0 ;clear LCD interrupt
low PORTC.5
high PORTC.3 ;apply power to LCD bias network
SwCount var byte
low PORTC.5
low PORTC.4
low PORTD.3
SwCount = 0
LCDPS = %00000000
LCDSE0 = %10110000 ;enable appropriate segment pins
LCDSE1 = %10010011
LCDSE2 = %11111110
LCDSE3 = %11111111
LCDSE4 = %11111111
LCDSE5 = %11
LCDCON = %11011111 ;enable LCD module
pause 10
gosub Dig1_1
goto Main
This is "num test" file:
Dig1_1: LCDDATA7.0 = 1
LCDDATA4.0 = 1
LCDDATA18.6 = 1
Can someone please tell me what I'm doing wrong? Thank you.
