hserin and sms controller
Results 1 to 26 of 26
    Nokia 7110 only work for me in 19600 bauds...
    Mar 2009
    Default simple device for sms controll of biomas heating device
    '*  Notice  : Copyright (c) 2009 [select VIEW...EDITOR OPTIONS] *
    '*  Date    : 18/03/2009                                        *
    '*  Version : 3.0                                               *
    '*  Notes   : lcd menu working fine, four temepratures in this  *
    '*          : example, but u can  easy update that, one phone   *
    '*          : authorized number,response from phone works fine  *
    '*  Notice  : Copyright (c) 2009                                *
    '*  Date    : 21/04/2009                                        *
    '*  Version : 2.0                                               *
    '*  Notes   : pic16F887, lcd 2X16 and ds1820 digital thermo.    *
    '*          : for remote (SMS) control of biomase heating device*
    '*          : with nokia 6210 and DL3P from www.atrox.at and    *
    '*          : with help from author of www.elektronika.ba,and Ioannis       *
    '* Autor    : Muamer Halilovic, www.mtskola.com                 *
    'pic defines
    	@ DEVICE pic16F887, WDT_OFF        ' Watchdog Timer
    	@ DEVICE pic16F887, PWRT_ON        ' Power-On Timer
    	@ DEVICE pic16F887, MCLR_ON        ' Master Clear Options (Internal)
    	@ DEVICE pic16F887, BOD_ON         ' Brown-Out Detect
    	@ DEVICE pic16F887, LVP_OFF        ' Low-Voltage Programming
    	@ DEVICE pic16F887, CPD_OFF        ' Data Memory Code Protect
    	@ DEVICE pic16F887, PROTECT_OFF    ' Program Code Protection
    'konfigurisi AN pinove kao digital I/O, portd kao I
    ansel=$00
    anselh=$00
    TRISD=$00
    portd=$00
    ' Definisanje hser-a (transmit-recive) i lcd-a u 4 bitnom modu
    define OSC 4
    DEFINE HSER_SPBRG 25
    DEFINE HSER_TXSTA 24h
    DEFINE HSER_RCSTA 90h
    DEFINE HSER_BAUD 9600
    DEFINE HSER_CLROERR 1
    DEFINE LCD_BITS 4
    DEFINE LCD_DREG PORTB
    DEFINE LCD_DBIT 0
    DEFINE LCD_RSREG PORTB
    DEFINE LCD_RSBIT 4
    DEFINE LCD_EREG PORTB
    DEFINE LCD_EBIT 5
    DEFINE LCD_LINES 2
    'definisanje varijabli
    high portd.7 ' aktiviranje uređaja
    low portd.7
    SYMBOL sel = PORTA.0    ' Sw 1 "trenutno stanje u objektu"
    symbol res = porta.1    'sw 2 "meni"
    SYMBOL enter = PORTA.2  ' Sw 3 "enter"
    T1 VAR BYTE
    T1=20
    ' promjenjive
    MENU VAR BYTE           ' zeljeni MENU
    POSI VAR BYTE           ' Pozicija na LCD
    temp Var Word			' temperatura kao word
    cr Var Byte			    ' ostatak
    cpc Var	Byte			' broji po stepenu C
    ow	Var	PORTE.2			' One-wire data pin
    i var byte              ' brojac
    posttemp var word       ' zeljena temperatura
    PORUKA VAR BYTE[3]      ' poruka kao array
    TELBR VAR BYTE[12]      'broj kao array
    TIME VAR BYTE [6]       'vrijeme kao array
    grijanje var byte       'grijanje kao bajt za ukljucenje i iskljucenje potrosaca
    grijanj var byte       'grijanje kao bajt za ukljucenje i iskljucenje potrosaca
    tmp var byte
    tbr var byte           'predefinisani broj korinsika
    IstaPoruka3 VAR byte     'varijabla za upoređivanje
    IstaPoruka1 var byte    'varijabla za upoređivanje
    istaporuka2 var byte     'varijabla za upoređivanje
    broj var byte
    x var byte               'brojac x
    K VAR BYTE              'brojac k
    L VAR BYTE              'brojac L
    J VAR BYTE              'brojac J
    ' incijalizacija
    'low portc.6
    low porte.2
    PAUSE 300       ' LCD inicijalizacija
    LCDOUT $FE,1    ' ocisti LCD
    MENU = 1        ' Inicijalizacija variablli
        x=0
        K=0
        L=0
        J=0
    LCDOUT $FE,130," DOBRO DOSLI"
    'lcdout $FE,$c0,128, "izaberite temp "
    lcdout $FE,$c0,"enter"," "," sel"," "," temp"
    ' meni switc select temp
    PAUSE T1
    poc:
    IF sel = 1 THEN
    gosub sc1
    goto poc
    izbor:
    if res = 1 then                     'ako je res pritisnut
     LCDOUT $FE,1                       'ocisti lcd
        MENU = MENU + 1                 'povecavaj vrijednost
        gosub amenu                     'idi na Amenu (odabir za prikaz na display)
        pause 200
        IF MENU = 5 THEN MENU = 1
        for i = 1 to 4
            if menu = i and enter=1 then gosub sc
        next i
    GOTO izbor
    'odabir za prikaz na displeju
    AMENU:
    SELECT CASE MENU
    CASE 2
    POSI = 129 : LCDOUT $FE,128,">" : LCDOUT $FE,POSI,"1."," 28.00" , " C"
    POSI = 193 : LCDOUT $FE,POSI,"2."," 30.00" , " C"
    CASE 3
    POSI = 129 : LCDOUT $FE,128,">" : LCDOUT $FE,POSI,"2."," 30.00" , " C"
    POSI = 193 : LCDOUT $FE,POSI,"3."," 32.00" , " C"
    CASE 4
    POSI = 129 : LCDOUT $FE,128,">" : LCDOUT $FE,POSI,"3."," 32.00", " C"
    POSI = 193 : LCDOUT $FE,POSI,"4."," 34.00" , " C"
    CASE 5
    POSI = 129 : LCDOUT $FE,128,">" : LCDOUT $FE,POSI,"4."," 34.00", " C"
    POSI = 193 : LCDOUT $FE,POSI,"1."," 28.00", " C"
    END SELECT
    'prikaz izabrane temperature
    sc:
    select case menu
    case 2
    posttemp=$0AF0' postemp = 2800
        LCDOUT $FE,1, "Max temp:","28.00 C"
        pause 2000
    case 3
    posttemp=$0BB8
        LCDOUT $FE,1, "Max temp:" , "30.00 C"
        pause 2000
    case 4
    posttemp=$0C80
        LCDOUT $FE,1, "Max temp:" , "32.00 C"
        pause 2000
    case 1
    posttemp=$0D48
        LCDOUT $FE,1, "Max temp:", "34.00 C"
        pause 2000
    end select
    'goto main
    Mar 2009
    Default rest of code
    ' provjeri sms inbox
    p:
    HSerout ["ATZ",13,10]                   ' pocni komunikaciju,resetuj modem!
    HSERIN 4000,p,[WAIT("OK")]
    tm:
    HSerout ["AT+CMGF=1",13,10]             'postavi text mod
    HSERIN 2000,tm,[WAIT("OK")]
    m:
    HSEROUT["AT+CPMS=",34,"SM",34,13,10]    'ciljana memory lokacija
    HSERIN 2000,m,[WAIT("OK")]
    ws:
    gosub sc1                               'odi provjeri temperaturu
    HSEROUT["AT+CMGL",13,10]                'filter za query
        LCDOUT $FE,1,"cekaj sms!"
    HSERIN 5000,ws,[WAIT("REC UNREAD"),skip 3,str telbr\12,skip 12,str TIME\6,skip 8,STR PORUKA\3\13]'trazi unread
    lcdout $FE,1,telbr[6],telbr[7],telbr[8],telbr[9],telbr[10],telbr[11]
    pause 3000
    tbr[6]="8"
    tbr[7]="3"
    tbr[8]="1"
    tbr[9]="0"
    tbr[10]="x"'your phone number last two digits, oli zadnje dvije cifre vaseg broja
    tbr[11]="y"
    broj=1
    for x=6 to 11
       if TELBR[x]<>tbr[x] then broj=0
    next x
    lcdout $FE,$c0,tbr[6],tbr[7],tbr[8],tbr[9],tbr[10],tbr[11]
    pause 2000
    IF broj=0 then gosub s4
    grijanje[1]="U"                                 'turn on heating
    grijanje[2]="G"
    istaporuka2=1
    FOR K=0 to 1
        if poruka[K+1]<>grijanje[K+1] then istaporuka2=0
    next K
    if istaporuka2=1 then gosub s1                     'ako se sve poklapa idi na slanje poruka
                                                        'ukljucene poreosaca
    grijanj[1]="I"                                  'turn off heating
    grijanj[2]="G"
    IstaPoruka1=1
    FOR L=0 to 1
        if poruka[L+1]<>grijanj[L+1] then IstaPoruka1=0 'ako se slova iz naredbe ne poklapaju
    next L                                               'istaporuk1=0
    if IstaPoruka1=1 then gosub s2                      'ako se sve poklapa idi na slanje poruka
                                                        'iskljucenje poreosaca
    tmp[1]="T"                            'ask for temperature in object
    tmp[2]="P"
    IstaPoruka3=1
    FOR J=0 to 1
        if poruka[J+1]<>tmp[J+1] then IstaPoruka3=0 'ako se slova iz naredbe ne poklapaju
    next j                                              'istaporuk1=0
    if IstaPoruka3=1 then gosub s3                      'ako se sve poklapa idi na slanje poruka
                                                        'temperatura u objektu
    ' brisanje poruke iz memeorije
    mm:
    HSERIN 2000,mm,[WAIT("OK")]
    d:
    HSEROUT["AT+CMGD=1",13,10]              'brisi poruku iz mem loc SM sa indexom 1
    HSERIN 2000,d,[WAIT("OK")]
            LCDOUT $FE,1,"sms izbrisan!"
            pause 1500
    GOTO ws
    'subrutines
    'subrutine za on/off-i potrosca i obavjest korisnika o poduzetoj akciji
    'i provjeru pristigle poruke
    s2:
      if IstaPoruka1=1 then low portd.0
        LCDOUT $FE,1,"isklj grijanje!"
        HSerout ["AT",13,10]
           Pause 1000
        HSerout ["AT+CMGF=1",13,10] 'Postavi Text Mode
           Pause 1000
        HSerout ["AT+CMGS=",34,"+387618310xx",34,",129",13,10]
        HSerout [str poruka\3,str time\6,10,13]
        s21:
            HSerout [26]
            hserin 6000,s21,[WAIT("OK")]
    s1:
        if istaporuka2=1 then high portd.0
            LCDOUT $FE,1,"uklj grijanje!"
                Pause 1000
                Pause 1000
            HSerout [str poruka\3,str time\6,13,10]
                s11:
                HSerout [26]
                hserin 6000,s11,[WAIT("OK")]
    'temperatura sa ds1820
    sc1:
       OWOut ow, 1, [$CC, $44]       ' pocni temp konverziju
    wc:
       OWIn ow, 4, [cr]	' provjeri da'l se jos konvertuje
       If cr = 0 Then wc
       OWOut ow, 1, [$CC, $BE]		' ocitaj temp
       OWIn ow, 0, [temp.LOWBYTE, temp.HIGHBYTE, Skip 4, cr, cpc]
       ' izracunaj temp u C na 2 decimale
      temp = (((temp >> 1) * 100) - 25) + (((cpc - cr) * 100) / cpc)
       Lcdout $fe, 1,"Trenutna temp:"' prikazi temp
       lcdout $FE,$c0,128,DEC (temp / 100), ".", DEC2 temp, " C"'"izaberite temp "
                if temp >= posttemp then gosub s3    ' ako je uslov ispunjen salji upozorenje
       pause 2000
     ' goto sc1
    'prekoracenje temperature salji sms s3 pozorenja i pogresan korisnik s4
    s3:
            LCDOUT $FE,1, "Salji temp!"
                Pause 1000
                Pause 1000
            HSerout ["Temp:",dec (temp/100),10,13]
            s31:
                HSerout [26]
                hserin 6000,s31,[WAIT("OK")]
    s4:
                LCDOUT $FE,1,"nemate prava!"
                Pause 1000
                Pause 1000
            HSerout ["AT+CMGS=",34,str telbr\12,34,",129",13,10]
            HSerout ["nemate prava",str time\6,13,10]
                s12:
                HSerout [26]
                hserin 6000,s12,[WAIT("OK")]
        goto mm
    Do you have any problem with this program, or ist an example?
    I have say to that is long enough! I have a little difficulty followng the s1, s12 named subs. Better use names to understand after a month what this sub do.
    Mar 2009
    its a example, but everything is working just fine, thos subs s1 to s4 is mesages for users!!!turn on heating, turn off heating, temperature in object and u dont have autorizathion for device!!! and once again thx for help!!!
    You are welcome. Thanks for posting your work too.
    After a lot of experimenting with the SMS subject, I noticed all by chance, that when my provider sent an SMS for advertisment purposes, the program could not handle it properly because in Hserin line to get the SMS, a 10 digit number was expected and not the 4 digit one.
    Keep in mind that the "defaults" may not always be default enough!
    Here is my test subroutine:
    read_sms:
    	Lcdout com,line1,"Reading SMS"
    	HSerout ["AT+CMGL=",34,"ALL",34,13]  '"ALL" is for Wavecom module. Read all SMS
    	' Read Caller ID etc. The timeout value in the HSERIN statement is important.
    	' it takes some time before the phone replies to the AT+CMGL command
    	HSerin 5000,ex_sms4,[wait("READ"),wait("+30"),str cc_phone\10,wait(44,44,34),SKIP 23,STR array\15\13] 'Number is waitstr command\10
    	LCDOut com,1,"Read 1 SMS"
    sms_delete:
    	LCDOut com,1,"Deleting SMS"
    	HSerout ["AT+CMGD=1,4",13]			'Delete all messages
    	HSerin 19000,ex_sms2,[wait("OK")]     'Wait for OK (null)
    	LCDOut com,line1,"Deleted SMS "
    	Pause 1000
    ex_sms2:    'No new message or timeout error
    	LCDOut com,line2,"Error",rep " "\11:Pause 1000
    ex_sms4:    'Wrong Number!
    	LCDOut com,line2,"Error phone Nbr":Pause 1000
    	goto sms_delete
    At the 3rd command line where HSerin 5000,ex_sms4,[wait... is executed, the command waits for +30 which is the country code for Greece, then I get 10 digits for the phone that is sending the SMS.
    But if the sender has only 4 digits I now through the timeout, jump to ex_sms4 and after an LCD message, the new and irrelevant SMS is deleted.
    Hope this helps all that deal with SMS stuff.
  1. Replies: 11
    Last Post: - 19th August 2009, 15:23
  2. problem with the GSM controller
    By Dariolo in forum mel PIC BASIC Pro
    Last Post: - 30th May 2009, 20:33
  3. Replies: 0
    Last Post: - 21st May 2009, 00:58
  4. parsing string from hserin
    By xxxxxx in forum mel PIC BASIC Pro
    Last Post: - 2nd April 2009, 18:42
  5. Reading a SMS to an array
    By KA5MAL in forum GSM
    Last Post: - 17th June 2008, 17:24
