18f24k20 & portb.1 (rb1)
Results 1 to 5 of 5
    Mar 2009
    Default 18f24k20 & portb.1 (rb1)
    Hello all,
    Finally have a question that the search hasn't answered for me. I have a pic18f24k20 that reads 8 a/d lines and then based on the values of the a/d lines it controls 8 additional output pins that control other things in this case an optoisolator. My issues is this: portb.1 will not go high when in a check loop for say a/d channel. The code runs and says it goes high but the output does not. However if I type high portb.1 in the main program loop it will take it high accordingly. This is the only issue I am having at this time with the code. The block of code being referenced is shown below along with appropriate registers.
    Thanks for the help in advance. Btw, great site.
    OSCCON = %01010111			'configure oscillator settings
    define OSC 4           'define oscillator as 4 Mhz
    TRISA = %00101111
    TRISB = %11111101
    TRISC = %11000000
    batcell1:
      'PortB.2-AN8, PortB.1-RB1
      adcon2 = %10110100
      adcon0 = %00100001
      Pauseus 50
      adcon0.1 = 1
      While ADCON0.1=1:Wend
    	adtmp.HighByte=ADRESH
    	adtmp.LowByte=ADRESL
    	rawad[0] = adtmp
    	adval[0] = rawad[0]
      if adval[0] => turnon then
        bypass[0] = 1
        high PORTB.1
        bypass[0] = 0
        low PORTB.1
    RB1 is also AN10.
    You need to disable the analog functions on the pins you want to use as digital.
    ANSEL and ANSELH
    Mar 2009
    Thanks for the reply I will give that a try tomorrow. I am still confused as to why it works in the main program loop that calls that sub show above with out having those set. I will let you know if it works.
    Mar 2009
    well what do you know...it works now. Many thanks. I guess I kinda missed the part about that changing when enabling A/D....oops
    If only Microchip would leave all that stuff turned OFF on power-up, things would be a lot easier.
    And this forum would have a couple thousand fewer threads.
    Glad you got it working.
  1. solar tracker controller
    By CIRE in forum mel PIC BASIC Pro
    Last Post: - 15th November 2016, 16:16
  2. reducing shiftout clock freq and PS2/PC interfacing ....
    By wireless magic in forum mel PIC BASIC Pro
    Last Post: - 26th February 2008, 21:15
  3. angular speed and gyrometer
    By fefenin in forum mel PIC BASIC
    Last Post: - 26th March 2007, 22:04
  4. Rb1 Problem On A 16f819..
    By Calco in forum mel PIC BASIC Pro
    Last Post: - 14th April 2004, 16:09
  5. Interupt for RB1 & RB2
    By itmsoil in forum mel PIC BASIC Pro
    Last Post: - 15th March 2004, 17:11
