HTTP help please
Results 1 to 13 of 13
    Apr 2008
    Default Ethernet Mini
    Chris,
    Maybe I did not make myself clear. At first I would like to use webpage that go into ethernet Mini to look up something on it. just like a router 192.168.01What I would like to make a simple task. I would like make port A0-A4, B0-B4 ,C0-C4, D0-D4 to turn it on (high) or off ( low) or read those port the value. I hope myself clear. I am not sure if we called it as web server or just remote the hub. I was hope someone has done this. I would like to see sample codes.
    Reid
    Hi Chris,
    Fred participates here, and makes contact info available on his web site. Your project idea might be just what he's looking for, why not ask Fred if it'll work?
    Hi Chris,
    In honesty the reason I posted was in the hope that Fred would contribute if he was able to assist or had the time to spare, and I've taken it that because he hasn't responded he had nothing to add. Perhaps he didn't read the message though ?
    I have completed the project now so I'm fine. Although I would still be interested if the ported ethernet stack could be adapted to work as a TCP port redirector, it could be usefuyl at some time in the future !
    Chris
    Quote Originally Posted by Reid View Post
    Chris,
    Reid
    Sorry Reid, mixed communications !
    By port number redirection I am referring to the TCP/IP port. EG HTTP uses port 80, and so on.
    The ethernet Mini appears to output raw packet data, which would require further desemination before you can get to the data you require. Although I don't have an ethernet Mini and may be speaking out of turn, it will demand some additional data processing to be applied before you get down to the basic transactions and connection handling.
    Have you looked into HTTP ?
    I guess from your message that you want to make some sort of remote control system, where you can send a command from a remote web connected PC, possibly via a browser, to interact with the hardware attached to the ethernet mini.
    You could do this a number of ways, from using HTTP to TFTP, SNMP could also work, but I would suggest looking into those protocols more closely to find the one best suited to the functionality you are looking for.
    Of course, you could easily implement your own protocol once you are handling TCP/IP or UDP directly, but it is usually a good idea to stick with accepted protocols over the internet.
    If you can explain more about the type of functionality you need, and if it needs to operate in both directions, we might be able to pin things down more precisely
    Dec 2003
    Storrs, Ct.
    Default Siteplayer
    You might want to have a look at the Siteplayer webserver. I've been using the Siteplayer for a few years now. Very easy to get started with. Been interested in Lantronics and also the Rabbit solution but never experimented with them. I know Microchip also offers some form of web interface but I've never been able to wrap my head around it.
    "It will never happen here!" just happened here.
    My thoughts and prayers for Sandy Hook victims and families.
  1. xport code, have example, confused though
    By kenpo in forum mel PIC BASIC Pro
    Last Post: - 30th March 2009, 20:59
