HTTP help please
Results 1 to 13 of 13
    Spamming my own thread with an update.
    I now have a Lantronix XPORT with Beta firmware tunneling the HTTP requests directly to it's serial output, connected to USART2 on a pic 18F87J10.
    The pic parses the GET string and gets the files from an SD card (attached to the SPI port) and serves them up, to make a web server.The dynamic nature and variable length data means that the HTTP data is output in chunked format.
    The files on the SD card are a combination of pre-made headers, and some dynamic files comprising data collected from a zigbee network, received via USART1
    Only serving pages at 56k for the time being, until I get the appropriate crystal, but I've finally got my gateway working, which is pleasing :-)
    The ready made HTML pages are made in Frontpage, saved to the root directory on the SD card, along with any images, and the card then plugs into the server.
    I need to include the PUT method now, so that I can upload pages to the SD card, then I've got the full server working !
    Sep 2005
    Campbell, CA
    I'm interested in your project, and would like to see your code when you get it completed. I'm using an XPORT as well, and with custom code which allows me to do SNMP.
    Charles Linquist
    Quote Originally Posted by Charles Linquis View Post
    Charles, the firmware in the XPORT may be the same firmware yoiu have. I am told it allows SNMP, but because I don't need to use it (can't think of anything 'creative' to do with it ?) I have not yet looked at it.
    The XPORT tunneling of HTTP on port 80 produces headers like....
    GET /index.htm HTTP/1.1
    Accept: image/gif, image/x-xbitmap, image/jpeg, image/pjpeg, application/x-shock
    wave-flash, application/vnd.ms-excel, application/vnd.ms-powerpoint, application
    /msword, */*
    Accept-Language: en-gb
    Accept-Encoding: gzip, deflate
    User-Agent: Mozilla/4.0 (compatible; MSIE 6.0; Windows NT 5.1; SV1; .NET CLR 2.0
    .50727; .NET CLR 1.1.4322)
    Host: 192.168.0.9
    Connection: Keep-Alive
    ....Which is useful because at last you can write your own pages without needing to store them on the COBOX, and that means that _dynamic_ pages with variable sized data fields can be used.
    I'm just using plain HTML right now but I've tried some Java objects and they seem to work fine.
    The only downside is that because I'm using SDFS which doesn't seem to support directories, all of my webpages are stored in the root directory.
    I'm just going to take a break but I'll leave the server running for you for the next hour or two. Not much to see but one page is
    http://92.8.106.11/MACMON01.htm
    and another is
    http://92.8.106.11/INDEX.HTM
    There's also an image on the SD card http://92.8.106.11/PICTURE.GIF
    Those pages are coming live from an SD card. They are complete files and the images are served correctly by subsequent GET methods (I didn't think the code would deal with that situation properly but to my pleasant surprise it does !)
    With the exception of the 'index.htm' file, ALL filenames are
    [8-characters] . [3-characters] , all in uppercase.
    Sep 2005
    Campbell, CA
    Impressive! I have a need for something like this. Collaboration?
    Charles Linquist
    Sure !
    I'm happy to hear what you're proposing :-)
    Apr 2008
    Default Ethernet Mini
    I am curious if any of you are still working on Ethernet Mini or not. I would like to make a small HTTP server. I am new on this. I would like to see your code or picture of your project.
    Reid
    Quote Originally Posted by Reid View Post
    Reid
    Reid,
    I used a Lantronix Xport-03, which has the ability to do port redirection between the ethernet socket and the two wire serial interface. This means that you can attach a pic to the serial port of the Xport and read the actual HTTP requests for files as they arrive, and in my case i responded by serving the suitable file from an SD memory card.
    I would recommedn that you look at the relevant RFC documentation covering things like HTTP, TFTP and FTP etc, because you will be working with it at a very low level if yoiu decide to go down this route.
    you would also need a fast method for serving files, which in my case consisted of reading a block of 512 bytes from the SD Card into a buffer on the pic and then using Hserout to transmit the buffer's contents to the serial port of the Xport. The actual etehernet side of things is dealt with for you by the Xport The SD Card used 2 wire SPI mode, which actually seemed quite slow in the end, especially when serving images >20kB in size and I would have preffered to use the 4 wire mode. But I got the SD software (SDFS) for free and mustn't complain.
    If you take a step back from what you are trying to achieve, you really are only moving large chunks of data between devices. The remote web server 'knows' what to do with the file it requested, yoiu simply need to send it when requested. Unless, you want to start serving live data. I ended up serving live data via an HTML file which is created only once, at the time the request for the data is made, and the usual HTML tags are inserted one by one as part of a loop. This probably also led to the program being slower than I would have liked.
    There are a lot of options available now for bridging a pic to the internet and I think yoiur best source of info is going to be the datasheets from the devices themselves. As well as the Xport, there is also something called a 'WebLynx' which seems to be similar although I am not sure if they are doing port redirection with that device yet.
    Chris
  1. xport code, have example, confused though
    By kenpo in forum mel PIC BASIC Pro
    Last Post: - 30th March 2009, 20:59
