Hey guys, will this work?
Results 1 to 27 of 27
    Feb 2004
    Michigan, USA
    Default Hey guys, will this work?
    Creating a buck converter and need to monitor a current sence voltage and change a pwm duty cycle based on the current sence ADC result. The target output current is user adjustable by a pot and a max current is set by a pot that is internal to the product and set at the factory. These pots are in series so only 1 input is needed. This is protection for a short at the output or the wrong load.
    So there are 2 inputs to the pic, the feedback from the current sence resistor and the voltage accross a potential divider for current set. I can set the hardware so that the current sence count and the current limit count are the same value when a given current target is met.
    Also, looking at the pbp pro manual I see a max HPWM of 32.767kHz yet the datasheet lists over 200kHz. Will the HPWM command actually allow a frequency of 200kHz? This is on a 18F1320.
    Here is what I think will work:
    OSCCON = $70
    define osc 8
    Define  ADC_BITS        10     	' Set number of bits in result
    Define  ADC_CLOCK       3     	' Set clock source (3=rc)
    Define  ADC_SAMPLEUS    10    	' Set sampling time in uS
    CSET   VAR WORD 'CURRENT SET
    CSEN   VAR WORD 'CURRENT SENCE
    DUTY   VAR wORD 'HPWM DUTY CYCLE
    ADCON0 = %00011001
    ADCON1 = %00001111
    ADCON2 = %10111111
    TRISA = %00000000
    TRISB = %00110011
    DUTY = 800 'SET INITIAL OUTPUT CURRENT HIGH TO ENABLE FAST STARTUP
    CSET = 0
    CSEN = 0
    LOOP:
    ADCIN 6, CSET 'READ VALUE OF CURRENT SET POT
    ADCIN 4, CSEN   'READ VALUE OF CURRENT SENCE
    IF CSEN > CSET Then LET DUTY = DUTY - 1
    IF CSEN < CSET THEN LET DUTY = DUTY + 1
    HPwm 1,DUTY,32767 'OUTPUTS THE DUTYCYCLE AT 32.767KhZ
    GOTO LOOP
    HPWM limit is as stated in your manual. To reach higher frequency, you need to write the PWM register manually. Use PICMultiCalc to find PR2 and Timer Prescaller value, then plug the DutyCycle values in CCP1CON and CCPR1L registers... double check your datasheet to confirm.
    For Buck converter, usually the higher the better for reducing coil and capacitors size.
    Make sure your ADCONx setting don't interfer with PBP ADCINs defines. You may want to place your define after those ADCONx lines, or get rid of ADCIN. Once again PICMultiCalc may give you some hints about min acquisition time and faster clock conversion source.... which is probably a must for buck converter. Don't forget to check the Resolution for the frequency you choosed. @8Mhz & 200KHz, you should have something like 7 bit of resolution.. 40 dutycycle steps... not bad, not good, depending how fancy you want it.
    In some case it's not a so good idea to use a PIC for that, just for the reaction time and what your PIC will also need to do apart the voltage regulation.
    Feb 2004
    Michigan, USA
    Hmm, eventually I have to get this running over 100kHz, so I will need to learn how to manually write to the registers and preload timers etc. I have never done this.
    All the links I've come across for the multicalc are dead. I had it once but lost it at some point.
    There is not much else going on with the pic really. If a pin goes high, it turns on a FET and runs the converter. Pin the goes low, it switches off. Thats it really.
    I've swapped the location of the DEFINE's.
    Other than that, at 32.767kHz, will that code do what I think it should do?
    In theory it should work. Theory is always theory
    PicMultiCalc download
    http://www.picbasic.co.uk/forum/atta...7&d=1225550328
    Probably you can get some inspiration of the following
    http://www.picbasic.co.uk/forum/show...0&postcount=10
    Feb 2004
    Michigan, USA
    Ok, so using the calc I get PR2 = 9, duty register = 20 and with a 1:1 prescaler.
    Is this about right?:
    OSCCON = $70
    define osc 8
    ADCON0 = %00011001
    ADCON1 = %00001111
    ADCON2 = %10111111
    TRISA = %00000000
    TRISB = %00110011
    'DUTY = 30 'SET INITIAL OUTPUT CURRENT HIGH TO ENABLE FAST STARTUP
    CSET = 0
    CSEN = 0
    duty = 20                           ' duty value for 50% duty cycle
    PR2 = 9                             '
    T2CON = %00000100                   ' timer2 on, prescale 1:1
    CCPR1L = duty>>2                    ' MSB of duty cycle value
    CCP1CON=%00001100 | (dUTY<<5)       ' set PWM mode and store the
                                        '   2 LSB of duty
    LOOP:
    IF CSEN > CSET THEN LET DUTY = DUTY - 1
                                        '   2 LSB of duty
    'HPWM 1,DUTY,32767 'OUTPUTS THE DUTYCYCLE AT 32.767KhZ
    GOTO LOOP
    Almost... but no cigar. Check CCP1CON for YOUR particular PIC. CCP1CON is a bit different on this one (and I think my example was false anyway ... dooh) as usual, MicroChip can't be consistent between all their PIC model. Good idea to release a datasheet for each and every different model though
    CCP1CON=%00001100 | (Duty<<4)
    Feb 2004
    Michigan, USA
    I did, it looks the same to me. I must have missed something.
    bit 7 and 6 are 00 = Single output; P1A modulated; P1B, P1C, P1D assigned as port pins
    bit 5 and 4 are the two LSbs of the PWM duty cycle. The eight MSbs are found in CCPR1L. I guess I do not know what to put in here or how to find out what should go in here. I thought duty>>2 took care of this.
    and 3 - 0 are 1100 = PWM mode; P1A, P1C active-high; P1B, P1D active-high
    The change is above... <<4 instead of <<5... but as i said... <<5 was wrong anyway... not sure why, but wrong anyways... few years after... no one complaint
    It is more code efficient... and obviously safer to use
    CCPR1L = duty>>2
    CCP1CON.4=Duty.0
    CCP1CON.5=Duty.1
    unless you'll screw up the CCP module on that 18F (think about the bit <7:6> of CCP1CON when duty value change). This was my major point here.
    Feb 2004
    Michigan, USA
    Ok, I think I understand all except how did you fill in bits 4 and 5? Why a 0 and 1 in the location you put them in?
    The lsb's of the duty cycle go in there. Its a 10 bit duty cycle. The top 8 are shifted away leaving to 2 lsb's. In decimal the duty cycle is 20. Is the binary representaion of 20 used? Is that how you get the last 2 bits?
    20 = 00010100 so the lsb's should be 00, no?
    Quote Originally Posted by jmgelba View Post
    assuming a 10 bits results as follow
    'Bit number 9876543210
       MyVar = %1111110011
    In red the MSB, in Blue the LSBs for PWM.
    Shift them all two position to the right you have
       MyVar = %0011111100
    Now, where are the LSB now... gone... you need to extract them 2 from the original 10bit value, so Bit0 and BIT1, and transfer them to Bit4 and BIT5 of CCP1CON register
    CCP1CON.4=MyVar.0 ' bit0 to bit4 of CCP1CON
    CCP1CON.5=Myvar.1
    Feb 2004
    Michigan, USA
    YES!! I understand at last!! Thank you so much for your time Steve.
    I have been looking at it all wrong. I can see moving the bits now. I thought each bit value, a 0 or a 1, was the 4 and 5 bit part of the number, so when you removed the lsb's, you shifted everything, and what was in 6 and 7 is now in 4 and 5 and is the new state.
    Feb 2004
    Michigan, USA
    Well now, of course, this does absolutly nothing!
    Here's the complete code.
    OSCCON = $70
    define osc 8
    DUTY   VAR wORD 'PWM DUTY CYCLE
    ADCON0 = %00011001
    ADCON1 = %00001111
    ADCON2 = %10111111
    TRISA = %00000000
    TRISB = %00110011
    Define  ADC_CLOCK       3     	' Set clock source (5=fosc/16)
    CSET = 0
    CSEN = 0
    PR2 = 9                             '
    CCP1CON.4=Duty.0                    ' set PWM mode and store the
    CCP1CON.5=Duty.1                    ' 2 LSB of duty
    LOOP:
    GOTO LOOP
    Feb 2004
    Michigan, USA
    Hehehe well it helps to actually turn on the PWM module!!
    Glitchy though. I've delayed the update by 1mS to smooth it out but still a big problem. Going to try disabling the PWM then updating the duty cycle and turning it back on.
    To get Glitch-Free, you have to synchronize the updates with Timer2.
    The HPWM10 module does that with 10-bit resolution, and works just like the HPWM command.
    http://www.picbasic.co.uk/forum/show...7805#post37805
    But at your higher frequency, you'll still need to do it manually.
    It does show how to though.
    hth,
    Feb 2004
    Michigan, USA
    Hi Darrel, I was just reading through that thread thinking it all looks familiar. I hadnt taken a look at your attachement yet.
    I'll have to digest in the morning. Is there a tutorial in your attachement, and will it work for 18F devices?
    I hate having one of those brains that learns by examples and questions rather than independant learning, feel so bad asking all the time. At least it usually goes in.
    I should drink more. Alcohol kills brain cells, therefore one could deduce that the slower brains cells are in contact with the alcohol longer, which would lead to them being killed off. This would leave you with only faster brain cells and thus more intelligence as the slower ones are no longer holding up your thinking. So on that thought, I'm going to the fridge to open a can of knowledge.
    There's not really a tutorial.
    But there is a test program in the .zip that shows how to use it.
    The max frequency is still 32.767khz.
    And it will work with 12F's, 16F's or 18F's. As long as they have CCP modules.
    However, while you grab me one of those cans of knowledge ...
    The whole thing boils down to synchronizing the update with TMR2.
    And HPWM10 has extra code to handle different frequencies/prescaler/CCP modules, which you won't need with a constant frequency on a single CCP.
    So all you need to do with your existing code, is wait for the TMR2IF before changing the dutycycle ...
    TMR2IF       VAR PIR1.1
    TMR2IF = 0
    while !TMR2IF : wend       ; let current cycle complete
    CCPR1L = duty>>2           ; MSB of duty cycle value
    CCP1CON.4=Duty.0           ; set PWM mode and store the
    CCP1CON.5=Duty.1           ; 2 LSB of duty
    No digesting required.
    Do I get that Can of knowledge now?
    Feb 2004
    Michigan, USA
    Sure do.
    I'll report in the morning, its about 2am and my 18 month old is coughing himself awake as I type. I've got a feeling its going to be a long night. Poor guy, always so sick. Yay for ear tubes on Thursday.
    Feb 2004
    Michigan, USA
    Well the little guy is sick and I got about 4 hours sleep last night.
    Havent tried this yet but I came up with this alternative and included Darrels changes.
    START:
    GOSUB NewDuty                '
    PAUSE 1
    GOTO Start
    NewDuty:
            TMR2IF = 0
            CCP1CON = 0
            CCPR1L = Duty >>2
            CCP1CON.5 = Duty.1
            CCP1CON.4 = Duty.0
            CCPCON.7 = 0
            CCPCON.6 = 0
            CCPCON.3 = 1
            CCPCON.2 = 1
            CCPCON.1 = 0
            CCPCON.0 = 0
    Poor little guy. :sad:
    As for the proposed additions ...
    You don't want to do that.
    The idea is to minimize the glitches, not create more.
    Leave the module in PWM mode and just change the dutycycle.
    Feb 2004
    Michigan, USA
    Hmm, well it dosent work. It's all over the place and then goes high and stays high. I have to power down to reset because adjusting the CSET pot does nothing to gain a recovery. Also, adc value for CSET does very little to alter the duty cycle.
    Is my thinking right here? Will this try to find the right duty cycle so CSEN = CSET?
    Refresh your duty cycle only when it need to, unless you'll have problem.
    try something like
    START:
            if DUTY != OldDuty then
                OldDuty = Duty
                GOSUB NewDuty
            GOTO Start
    NewDuty:
            TMR2IF = 0
            CCP1CON = 0
            CCPR1L = Duty >>2
            CCP1CON.5 = Duty.1
            CCP1CON.4 = Duty.0
    You'll probably need to allow an error margin in your IF-THEN, remember you have a 7 bits or so PWM resolution but 10Bit ADC results. Reduce your ADC resolution to 8 bit may help.
    You also want to make sure you don't overflow the Duty value...
    Seeing your schematic would be nice.
    Does this work OK?
    OSCCON = $70
    DEFINE OSC 8
    DUTY   VAR WORD 'PWM DUTY CYCLE
    O_Duty VAR WORD 'previous Duty-cycle
    MinDuty CON 2   'minimum duty cycle
    MaxDuty CON 40  'maximum duty cycle
    ADCON0 = %00011001
    ADCON1 = %00001111
    ADCON2 = %10111111
    TRISA = %00000000
    TRISB = %00110011
    CSET = 0
    CSEN = 0
    DUTY = 20           ' duty value for 50% duty cycle
    PR2 = 9             '
    CCPR1L = DUTY>>2    ' MSB of duty cycle value
    CCP1CON.4=DUTY.0    ' set PWM mode and store the
    CCP1CON.5=DUTY.1    ' 2 LSB of duty
    CCP1CON = %00001100
    LOOP:
    ADCIN 4, CSEN   'READ VALUE OF CURRENT SENSE
    ' test for CSEN > CSET*2
    IF CSEN > (CSET*2) THEN  ' minimize short-cycling (increase as needed)
       IF DUTY > MinDuty THEN ' don't allow below minimum duty
          DUTY = DUTY - 1
    IF CSEN < (CSET/2) THEN
       IF DUTY < MaxDuty THEN ' don't allow greater than max duty
          DUTY = DUTY + 1
    IF O_Duty = DUTY THEN LOOP ' does duty-cycle need updating?
    O_Duty = DUTY    ' yes. copy last duty value for next comparison
    GOTO LOOP
    A low-pass filter on each A/D input would also help.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    At 200khz, you only get a Duty range of 0-40.
    Not going to be a very precise regulator with that.
    Your previous examples were at 32.767khz, which PicMultiCalc shows 0-244 duty range (better). But like mister_e said, you'll need to limit the range.
    With a 20mhz crystal you can get 0-610 @32khz, or 0-100 @ 200khz.
    Feb 2004
    Michigan, USA
    Guys thanks for the ideas and snippets. I have not been around today to work on this. I need to up the frequency to 300KHz now to reduce inductor size and value. I was going to use a 20mhz resonator but just wanted to get something up quick and dirty so I used the internal osc at 8mhz.
    My schematic is a scribble on a piece of paper at the moment, but its essentially a classic buck converter design that could be found anywhere on the web. I think some of the problem is ripple voltge on the 5v line. This changes the internal vref of the adc.
    I'll mill or get the boys in the shop to etch me a pcb in the morning so I can load up on the capacitance and cut down on the noise.
    Oh, last night, I killed 12 Osram Dragon infra red led's that are not mine. Oops. I think they are something like $15 a piece
    1 or 2 is OK. But 12..????
    Next time put a Dummy load first.
    Feb 2004
    Michigan, USA
    It was a mistake. I have a test box where I can push a few buttons and switch between different types, numbers and colors of LED's. I use it to test drivers that are new and about to be installed into a product. I also have some power resistors in there which are my dummy loads. I pressed the wrong switch and connected 12 IR led's instead of the dummy load. I put 23v through 2 strings of 6. The have about 1.8vdrop each typically.
    It was not a good night.
    Feb 2004
    Michigan, USA
    OK, I found some time to try Bruce's code and I got the same results. At a very high and very low feedback signal the PWM signal disappears and the output goes 100% high. If the feedback signal varies rapidly the PWM goes 100% low.
    I took off all the switching components to remove any chance of noise and just used a pot to vary a fake feedback voltage and got the same results.
    I am going to try the code and ciruit used in the AN1130 app note. My schematic is different to this - I have the inductor on the positive side of the LED's and use a PFET.
    My requirements are also different.
    Input = 24v
    LED forward V = 21V (6x blue LED's with 3.5vdrop each)
    LED I = 700mA
    Current Ripple = 10%
    Switiching Frequency = 200KHz
    I calculate the inductor value to be 131uH. I will have to lower the gain on the feedback opamp from 11 to maybe 5 or something. I'll figure that out later - just a simple resistor value change.
    I'm going to spend a bit of time trying to convert the code from C to PICBasic. I've havent used C before so that will take me a while to actualy figure out what the heck void and so on means.
  1. PortA Doesn't Work
    Last Post: - 8th September 2015, 18:41
  2. pls help me verify my code not work, why???
    Last Post: - 18th January 2010, 09:19
  3. Can't get POT work on P12f675 - Newbie
    By berslan in forum mel PIC BASIC Pro
    Last Post: - 26th March 2008, 21:22
  4. How to set ICD-2 clone to work with PBP?
    By G-R-C in forum mel PIC BASIC Pro
    Last Post: - 20th October 2006, 02:50
  5. Pin RA4 doesn't work
    Last Post: - 15th July 2004, 12:03
