12f629 vs ATtiny 11L
Results 1 to 12 of 12
    Sep 2007
    USA, CA
    Quote Originally Posted by AMay View Post
    You are too advanced for me, I don't recognize the code. I know PIC Basic some, and a little assembler. ...
    This (see quote above) is why you thought the code was as tight as possible, yet you were only getting 10kHz. PBP is extremely inefficient. It is very simple and very nearly idiot-proof, but most certainly not the compiler to use if you are trying to get tight, fast running code.
    Hi Cliff,
    Sorry, but I don't agree with that statement. PBP is quite efficient, and one of the least
    buggy
    BASIC compilers out there.
    It may not produce the tightest code for a BASIC compiler, but it's for sure one of the
    most reliable, and it's very simple to include just a few lines of assembly code when you
    need tight timing like this.
    What BASIC compiler would you recommend & why?
    If you know of a PIC BASIC compiler that's more reliable & efficient than PBP, I would
    love to see your test results...;o}
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    USA - Arizona
    Chuck Hellebuyck wrote a cool article on Nuts & Volts Magazine (April 2007, and June 2007). It did a quick comparison between different compilers, and I have to say was very surprised. PicBasic Pro fared extremely well.
    Aug 2005
    Houston, TX
    Default Got it to work
    While I still have trouble with Bruce's code, I went back to the PIC data sheet, and tried the following code which delivers 113Khz, and the circuit delivers 15.2 volts out to 5 high bright LEDs. 4.5v in at 80ma. The LEDs are quite bright.
    From Microcode studio, using PIC Basic (not Pro.)
    Settings:
    poke $19, $7 'Disable comparators
    low 0
    LOOP
    BSF 005H,0 ;set bit 0, Pin 0 high
    NOP ; kill time, 1us
    NOP
    NOP
    NOP
    NOP
    CLRF 005H,0 ;clear bit 0
    GOTO LOOP
    Sep 2007
    USA, CA
    Quote Originally Posted by languer View Post
    I would venture to guess that the biggest reason it did so well is because NV refuses to accept articles which contain the Proton compiler. If you eliminate the most competent alternatives, it is easy to say you are the best. And yes, I own both compilers.
    USA - Arizona
    Quote Originally Posted by tenaja View Post
    This may be true. I have no evidence to prove or disprove this. I do want to make a disclaimer, I am not a PBP or Proton guy. I do own an old version of PBP but have not used it in a long while. I have used C for a long, long time now.
    Regardless, after the initial article Chuck did get quite a bit of information from different camps (including myself from the C camp). And the reason I said I was quite surprised, was that for this test (and the test was quite simple - so one should not read too much into this) Proton and PBP achieved the same speed, as well as CCS C. And HiTech C was only slightly faster.
    I believe the memory usage was better for the C compilers, but cannot say for sure without revisiting the articles and e-mail conversations.
    Most important thing is that beauty is in the eye of the beholder, and what works for one may not work for the other.
  1. Input problems with 12F629?
    By achilles03 in forum mel PIC BASIC Pro
    Last Post: - 24th April 2018, 07:25
  2. 12F629 LDR - Light Dependant Resistor
    By Dennis in forum Schematics
    Last Post: - 18th February 2010, 23:33
  3. 12f629 config settings
    By Dennis in forum mel PIC BASIC Pro
    Last Post: - 1st December 2009, 23:39
  4. Basic help for 12F629
    By Gene Choin in forum mel PIC BASIC
    Last Post: - 22nd September 2009, 05:06
  5. Servo control with 12F629
    Last Post: - 24th June 2005, 00:34
