32 bit square root
Results 1 to 21 of 21
Threaded View
  1. #11
    Default Assembly code now working
    I compared your assembly code to the original Microchip TB040 to see if I could make it work. I did notice that a = 0 in the document, and in your code, every place that a was, now = 1. I am not very good at assembly, so I would like to know the difference between:
            movwf BITLOC0, 1
    and
            movwf BITLOC0, 0
    But, after doing this, I was able to get both the 16 bit and 32 bit working. I did not try setting them all back to 1, to see if that made a difference. But I did accidentally leave in one "1", and it did not work until I made it a zero. I am very curious to know the speed differences of each, if you have done any tests.
    Walter
    Sqrt tstfsz ARGA3,0 ; determine if the number is 16-bit
            bra Sqrt32 ; or 32-bit and call the best function
            tstfsz ARGA2, 0
            bra Sqrt32
            clrf RES1, 0
            bra Sqrt16
    Sqrt16 clrf TEMP0, 0 ; clear the temp solution
            movlw 0x80 ; setup the first bit
            movwf BITLOC0, 0
            movwf RES0, 0
    Square8 movf RES0, W, 0 ; square the guess
            mulwf RES0, 0
            movf PRODL, W, 0 ; ARGA - PROD test
            subwf ARGA0, W, 0
            movf PRODH, W, 0
            subwfb ARGA1, W, 0
            btfsc STATUS, C, 0
            bra NextBit ; if positive then next bit
        ; if negative then rotate right
            movff TEMP0, RES0 ; move last good value back into RES0
            rrncf BITLOC0, F, 0 ; then rotote the bit and put it
            movf BITLOC0, W, 0 ; back into RES0
            iorwf RES0, F, 0
            btfsc BITLOC0, 7, 0; if last value was tested then get
            bra Done ; out
            bra Square8 ; elso go back for another test
    NextBit movff RES0, TEMP0 ; copy the last good approximation
            rrncf BITLOC0, F, 0 ; rotate the bit location register
            movf BITLOC0, W, 0
            iorwf RES0, F, 0
            btfsc BITLOC0, 7, 0 ; if last value was tested then get
            bra Done ; out
            bra Square8
    Done movff TEMP0,RES0 ; put the final result in RES0
            bra TotallyDone
    Sqrt32 clrf TEMP0, 0 ; clear the temp solution
            clrf TEMP1,
            clrf BITLOC0, 0 ; setup the first bit
            clrf RES0, 0
            movlw 0x80
            movwf BITLOC1, 0 ; BitLoc = 0x8000
            movwf RES1, 0 ; RES = 0x8000
    Squar16 movff RES0, ARG1L ; square the guess
            movff RES1, ARG1H
            call Sq16
            movf SQRES0, W, 0 ; ARGA - PROD test
            subwf ARGA0, W, 0
            movf SQRES1, W, 0
            subwfb ARGA1, W, 0
            movf SQRES2, W, 0
            subwfb ARGA2, W, 0
            movf SQRES3, W, 0
            subwfb ARGA3, W, 0
            btfsc STATUS, C, 0
            bra NxtBt16 ; if positive then next bit
            addlw 0x00 ; clear carry
            movff TEMP1, RES1
            rrcf BITLOC1, F, 0 ; then rotote the bit and put it
            rrcf BITLOC0, F, 0
            movf BITLOC1, W, 0 ; back into RES1:RES0
            iorwf RES1, F, 0
            movf BITLOC0, W, 0
            iorwf RES0, F, 0
            btfsc STATUS, C, 0 ; if last value was tested then get
            bra Done32 ; out
            bra Squar16 ; elso go back for another test
    NxtBt16 addlw 0x00 ; clear carry
            movff RES1, TEMP1
            rrcf BITLOC1, F, 0 ; rotate the bit location register
            rrcf BITLOC0, F, 0
            movf BITLOC1, W, 0 ; and put back into RES1:RES0
            iorwf RES1, F, 0
            movf BITLOC0, W, 0
            iorwf RES0, F, 0
            bra Done32 ; out
            bra Squar16
    Done32 movff TEMP0,RES0 ; put the final result in RES1:RES0
            movff TEMP1,RES1
            bra TotallyDone
    Sq16 movf ARG1L, W, 0
            mulwf ARG1L ; ARG1L * ARG2L ->
        ; PRODH:PRODL
            movff PRODH, SQRES1 ;
            movff PRODL, SQRES0 ;
            movf ARG1H, W, 0
            mulwf ARG1H ; ARG1H * ARG2H ->
        ; PRODH:PRODL
            movff PRODH, SQRES3 ;
            movff PRODL, SQRES2 ;
            movf ARG1L, W, 0
            mulwf ARG1H ; ARG1L * ARG2H ->
        ; PRODH:PRODL
            movf PRODL, W, 0 ;
            addwf SQRES1, F, 0 ; Add cross
            movf PRODH, W, 0 ; products
            addwfc SQRES2, F, 0 ;
            clrf WREG, 0 ;
            addwfc SQRES3, F, 0 ;
            movf ARG1H, W, 0 ;
            mulwf ARG1L ; ARG1H * ARG2L ->
        ; PRODH:PRODL
            movf PRODL, W, 0 ;
            clrf WREG, W ;
    TotallyDone
    Last Post: - 14th June 2016, 07:55
  2. Replies: 3
    Last Post: - 18th March 2008, 04:29
  3. PICBasic newbie problem
    Last Post: - 12th February 2008, 00:55
  4. 32 bit data displaying on LCD
    By selahattin in forum mel PIC BASIC Pro
    Last Post: - 15th September 2006, 13:33
    Last Post: - 6th March 2005, 01:07
