32 bit square root
Results 1 to 21 of 21
    Sep 2005
    Campbell, CA
    Thanks! I'm at the point where a hundred cycles makes the difference whether my ISR gets messed up or not.
    Charles Linquist
    Hi, Charles
    Did you see that one ???
    http://www.piclist.com/techref/micro...qrt/sqrt32.htm
    Sep 2005
    Campbell, CA
    No, I missed that one. I'll give it a try.
    I'm calculating the RMS currents of several non-sinusoidal waveforms simultaneously, along with checking limits and times, and sending the results on to another PIC for display and data collection. I have to sample frequently to get enough accuracy, and I have to do everything on a cycle-by-cycle basis.
    Charles Linquist
    Sep 2005
    Campbell, CA
    I see that the 'movfp' instruction is used in the example. I'm not familiar with the 16F or 17F parts. Is that instruction equivalent to the 18F instruction 'movf' ?
    Charles Linquist
    Hi, Charles
    it's just a particular Movf for PIC 17 ...
    from f : Register file address (00h to FFh)
    to p : Peripheral register file address (00h to 1Fh)
    I do not see any warning to use a simple " Movf " with a 18F Device ... ( banking may be ??? )
    Last Post: - 14th June 2016, 07:55
  2. Replies: 3
    Last Post: - 18th March 2008, 04:29
  3. PICBasic newbie problem
    Last Post: - 12th February 2008, 00:55
  4. 32 bit data displaying on LCD
    By selahattin in forum mel PIC BASIC Pro
    Last Post: - 15th September 2006, 13:33
    Last Post: - 6th March 2005, 01:07
