GP3 Funtion on PIC10f202
Results 1 to 8 of 8
    Quote Originally Posted by kessral View Post
    In Configuration Bits "Master Clear Enable" is set to "Function as GP3" already, sorry forgot to mention that
    Not sure where you are setting the config? You have some program that is doing it for you?
    You will need to modify the *.inc file in the PBP directory to set the configs correctly.
    This thread may help explain it. It talks about setting the configs in code space and what to do to make it happen.
    And like Alan pointed out. TRIS for this application and pin should be 1.
    Jan 2007
    Oh thank you! Don't know how I missed all this before but after some headache and commenting out 2 lines in the .INC file it works great!
  1. problem with variable on PIC10f202
    By Samoele in forum mel PIC BASIC Pro
    Last Post: - 26th October 2009, 18:29
  2. PIC10F202 Variable trouble
    By George in forum mel PIC BASIC Pro
    Last Post: - 13th October 2006, 03:14
  3. using gp3 12f629
    By grounded in forum Schematics
    Last Post: - 23rd August 2005, 22:15
  4. Problem with Picbasic Pro and PIC10F202, PIC10F206
    By mikaljan in forum mel PIC BASIC Pro
    Last Post: - 11th May 2005, 22:02
