Compile and Program help using PICKit2
Results 1 to 16 of 16
    Default Compile and Program help using PICKit2
    Hi all
    I'm still learning how to use PBP - after using only assembly.
    I can't seem to get the compile and program feature to work - (or program only for that matter). What I end up doing is compile in PBP, then exit, and import and program the hex file using PICKit directly. That works fine. When I try to use Compile and Program, MCS searches for the PICKit , but does not seem to find it - it just stops and does not program. The proper device is selected - in this case a 16f870. The PICKit is plugged in to the USB port, and the chip is inserted into the programming socket.
    From the Compile and Program Option, I have PICKit selected as the default programmer.
    I'm missing something simple - please help.
    Ken
    Hi Ken,
    This just got discussed recently, and I think this is the link:http://www.picbasic.co.uk/forum/showthread.php?p=68368
    Welcome to the forum.
    Thanks . . .
    Yes, I found that thread after some more searching. Still don't have it quite right I guess, but I'll keep trying.
    Ken
    I have not even tried to make it work as I like the pickit2 software as is. I open the pickit2 software and MCS, compile from MCS and load from PICkit2.
    At this point I agree. I have been pulling my hair out trying to get this to work - must be missing a - or $ or something.
    Anyway, to h*** with it. I will stick to using the PICKit software - like you do and I have been doing.
    LOVE Pic Basic Pro however !
    Ken
    Ok this works, I just set mine up Thanks to Darrel Taylor:
  1. Connecting programmer to MicroCode Studio
    By KrashKaloop in forum mel PIC BASIC Pro
    Last Post: - 15th July 2014, 23:22
  2. Presetting Configuration Fuses (PIC Defines) into your Program
    Last Post: - 15th December 2013, 10:54
  3. Making Program Code Space your playground...
  4. Problem to compile my program
    By wagner in forum Off Topic
    Last Post: - 7th July 2008, 21:17
  5. Replies: 2
    Last Post: - 9th February 2006, 23:03
