Fatal xxx.ASM 527: [308] macro buffer overflow
Results 1 to 5 of 5
    Feb 2009
    Default Fatal xxx.ASM 527: [308] macro buffer overflow
    I installed PB Pro on my laptop to make my development portable. It runs, but I get "Fatal xxx.ASM 527: [308] macro buffer overflow" on a known good program when compiling.
    I saw a similar thread on this forum but there was no resolution documented.
    TIA,
    TR
    From PM.txt.
    308 Macro Buffer Overflow
    An attempt was made to define a macro which was larger than 4K. This
    usually indicates a missing ENDM pseudo-op.
    You may have a macro without ENDM.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Feb 2009
    Hi Bruce,
    Thanks for your help!
    I saw that, but it doesn't seem to apply in this case. This exact code compiles and runs perfectly on my desktop machine!
    Any other ideas?
    TIA,
    TR
    Zip-up the code you're having the problem with and I'll see if I get the same error here.
    -Bruce
    tech at rentron.com
    Feb 2009
    I'm not exactly sure why but it started working. If it may help someone else here's what I did....
    I created a simple test program, and compiled it and it worked. Then I added Include "Modedefs.bas" and I got a message saying that it needed to use MPASM. I had it find MPASM, then it compiled. So I went back to my original program and recomplied and it said it the filename path was too long by 4 bytes. I shorted the filename and then it compiled ok.
    Go figure....
