Matrix _16f877 need help, please
Results 1 to 12 of 12
    Apr 2008
    Default Matrix _16f877 need help, please
    Currently i write a code to run a led matrix. the following is a one led set to be lighted up. the positive pin of the LED is connected to port B0. and negative, to port C1.
    the X-tal OSC is 20Mhz, HS_osc is placed in the 16F877.INC file; OSC. set to HS
    MCLR is connected directly to the 5V source.
    i use PBP
    ; 16F877A
    ADCON1 = 7
    A VAR BYTE
    PORTB = 0 ; SET PORTB AS OUTPUT
    PORTC = 0 ; set port c as output
    PORTC.1 = 0 ; set port C1 to low
    pause 300
    LOOP:
    FOR A = 0 TO 8 loop to repeat
    PORTB.0 = 1 set port B0 to high
    PAUSE 500
    PORTB.0 = 0 ; set port B0 to low
    PAUSE 300
    NEXT A
    GOTO LOOP
    the Voltage measurement on the two pins of the LED is 1.65V!!!!!!!
    something wrong!!!!!!!!!!
    any help from you i do appreciate, thanks
    Hi MINHLE,
    try this
    ADCON0 = 0
    ADCON1 = 7
    A VAR BYTE
    trisB = %00000000 'all ports B as outputs
    TrisC = %00000000 'all ports C as outputs
    PORTC.1 = 0 ; set port C1 to low wich enables leds ground pin
    CCP1CON = 0 ' turn off CCP Module which affects portC
    pause 300
    LOOP:
    FOR A = 0 TO 8 'loop to repeat
    PORTB.0 = 1 'set port B0 to high, turn on led
    PAUSE 500
    PORTB.0 = 0 ; set port B0 to low, turn off led
    PAUSE 300
    NEXT A
    GOTO LOOP ' Flash forever
    The only difference is I set Tris registers and disabled Capture Compare Module. and turned off A/D converter. Now how have you set your config fuses? You have specified 20 mhz and this will not work with the default config statement found in the C:\PBP\16f877.inc file.
    Apr 2008
    THANKS jOE,
    I TRY AGAIN AS YOUR SUGGESTION.
    I WILL SET THE OSC TO 20MHZ, AND CHECK THE DATA SHEET
    THANKS
    In case you change XT to HS osc in your .inc file, make sure you've made the change for the right assembler... this is 1 reason why I set my fuses in code, not in the .INC file.
    Apr 2008
    hi, Joe and Steve,
    thanks for your concern. I tried testing but no thing happen. is it possible the two capacitors of the osc-xtal is the main problem.
    I saw in the data sheet, for the Hs (20Mhz) xtal osc, the capacitors are range 15-33pF. but i use only 10uF! (table 14-2 page 144 of the data sheet).
    Quote Originally Posted by MINHLE View Post
    hi, Joe and Steve,
    µ is Way bigger than pf Way too big !10µF will oscillate in kilohertz, not mhz.
  1. led matrix pic 16f84 and 4017 help me please
    By Mus.me in forum mel PIC BASIC Pro
    Last Post: - 5th February 2011, 00:06
  2. RGB LED Matrix
    By ERIK in forum mel PIC BASIC Pro
    Last Post: - 28th June 2008, 07:01
  3. LED Matrix Question
    By mekohler in forum Schematics
    Last Post: - 29th September 2007, 13:12
  4. 4x16 Dot Matrix LCD control is possible?
    By muskut in forum mel PIC BASIC Pro
    Last Post: - 1st September 2005, 09:56
  5. need help with switch matrix
    By Srigopal007 in forum mel PIC BASIC Pro
    Last Post: - 26th January 2005, 18:59
