Problem with serin2 serout2
Results 1 to 6 of 6
    Dec 2008
    Default Problem with serin2 serout2
    Hi for all friend
    with serial communication between two 16F84A I send a varible b0 from firt To second pic
    code :
    MAIN:
    FOR B0=4 T0 200
    SEROUT2 0,T9600,[DEC1 b0]
    PAUSE 10
    NEXT BO
    GOTO MAIN
    the second pic recieved only first byte B0=4 BY
    SERIN2 0,T9600,[DEC1 b0]
    but why second pic can't recieved variable from 4 TO 200
    I USE OSC 4MHZ
    THANK YOU FOR YOUR INTERSTING
    Have you tried [DEC b0] on both ends?
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Dec 2008
    yes i try [DEC b0] but nothing changed pic recieved only first byte
    May 2008
    Italy
    To use 9600,n,8,1 with Serin2/Serout2, code should be:
    SEROUT2 Pin,84,[DEC b0]
    SERIN2 Pin,84,[b0]
    What does your program after the serin2 with the byte received? Very likely the second byte arrives when receiver is not yet ready, increase the Pause to 1000 and see if it works than reduce it gradually to the optimum.
    Al.
    DEC causes numbers to be sent in ASCII format. 1 to 9 will work fine since each number will
    be a single ASCII character. When you get to 10, it sends an ASCII 1 followed by an ASCII
    0, which requires two bytes. DEC 100 will be 3 ASCII bytes, etc.
    Try something like this;
    T9600 CON 84
    MAIN:
    FOR B0=4 T0 200
    SEROUT2 0,T9600,[B0] ' without modifier, sends the unformatted byte value of 4 to 200
    PAUSE 10
    NEXT BO
    SERIN2 0,T9600,[B0] ' can receive a value from 0 to 255
    -Bruce
    tech at rentron.com
    Dec 2008
    hi all my friends
    thank you for your reply
    yes Mr ARATTI it's works good with
    Pause 100
    SERIN2 Pin,84,[b0]
    thank you very much and thanks for Mr Bruce
    Although I don't try yet his code
    good luck
  1. Serout and 18F87J50
    By Glenn_Webber in forum Serial
    Last Post: - 20th November 2009, 15:26
  2. SLOW Serin2 and Serout2
    By dragons_fire in forum General
    Last Post: - 26th June 2009, 03:38
  3. Serout2 and Serin2 problem
    By MrSafe in forum mel PIC BASIC Pro
    Last Post: - 26th July 2007, 05:33
  4. SEROUT2 and SERIN2 commands
    By bangunprayogi in forum mel PIC BASIC Pro
    Last Post: - 4th August 2005, 10:03
  5. Simple PC Menu System with Serin2
    Last Post: - 3rd April 2005, 09:27
