ARCSIN function
Results 1 to 4 of 4
Thread: ARCSIN function
    Default ARCSIN function
    Is there anyway to calculate an ARCSIN in PBP? I am trying to use an accelerometer to determine velocity of an arm moving in an arc. My problem with using the direct output of the accelerometer is that it is a function of SIN. If I can convert the numbers to an angle I will have a linear relationship. Can anyone help?
    May 2008
    Italy
    A very good approximation is given by this polynomial.
    arcsin(x) = pi/2 - sqrt(1 - x)(a0 + a1*x + a2*x^2 + a3*x^3)
    where constant are as follow:
    a0 = 1.5707288
    a1 = -0.2121144
    a2 = 0.0742610
    a3 = -0.0187293
    Tray it and see if this polynomial will solve your problem.
    Al.
    May 2008
    Italy
    I have been thinking to a simpler way to solve your problem, and I came to the conclusion that you should use XY coordinates to trace the point on the arc where your arm moves. Your accellerometer gives you the sin value of the move than you read position zero= X0Y0 and position one = X1Y1 after the move, and so you have the possibility to linearise your data.
    You can calculate the XY coordinate with this equation:
    X= R * Sin
    Y= R * sqr(1-Sin^2)
    Where:
    R = lenght of your moving arm
    Sin = value given by accellerometer.
    This is a much simpler way to handle this data with PBP.
    Al.
    Wink
    Centrifugal acceleration equals (-) R x Omega^2 ...
    measuring acceleration and angular speed and knowing lenghth of the arm ...
    in Ze Pocket ...
    Ok ... you must substract gravity ... Ok !
    but just need angular position ...
    correction is easy ... with a retrieve table ( LOOKUP ) that can reach up to 256 values ...
    Did I miss anything ???
  1. Single button function
    Last Post: - 4th April 2020, 18:33
  2. Hash function
    By Ioannis in forum mel PIC BASIC Pro
    Last Post: - 7th September 2007, 10:09
  3. Need help with write function
    Last Post: - 12th July 2006, 04:12
  4. ATAN2(,) function
    By vk2tds in forum PBP Wish List
    Last Post: - 25th November 2005, 02:52
  5. Random function - How to limit it ??
    By martarse in forum mel PIC BASIC Pro
    Last Post: - 30th November 2004, 14:05
