Compile and Program help using PICKit2
Results 1 to 16 of 16
    Hi Ken,
    This just got discussed recently, and I think this is the link:http://www.picbasic.co.uk/forum/showthread.php?p=68368
    Welcome to the forum.
    Thanks . . .
    Yes, I found that thread after some more searching. Still don't have it quite right I guess, but I'll keep trying.
    Ken
    I have not even tried to make it work as I like the pickit2 software as is. I open the pickit2 software and MCS, compile from MCS and load from PICkit2.
    At this point I agree. I have been pulling my hair out trying to get this to work - must be missing a - or $ or something.
    Anyway, to h*** with it. I will stick to using the PICKit software - like you do and I have been doing.
    LOVE Pic Basic Pro however !
    Ken
    Ok this works, I just set mine up Thanks to Darrel Taylor:
    biggej's Avatar
    biggej Guest
    Default My settings work too
    Ken,
    My settings are a bit different than Darrel's but may have required a download of a command processor from Microchip.
    In the program filename box I have pk2cmd.exe
    The path should point to your "pickit 2 v2" directory which is likely
    C:\program files\microchip\pickit 2 v2
    My parameters string is
    -PPIC$target-device$ -F$hex-filename$ -E -M -Y -Y
    This works with or without the PicKit program running as it brings up a batch programming window. The -Y -Y causes the verification to run twice just so you can see the results of programming before the batch window closes.
    I usually run the PicKit program also so I can use its reset MCLR function to start the code running in the pic.
    Hope this helps,
    Jim
    First of all - thanks to all who have responded and made suggestions on this.
    I simply cannot get this to work -
    I went so far as printing out the page that Darrel posted with his step - by - step instructions, and - as far as I know - after three times - followed them to the letter.
    Obviously not - all that happens is the project compiles, there is a momentary screen flash after successful assembly - then nothing, just success at compiling. I tried Jim's code as well - same thing.
    Also deleted previous attempts at selecting the programmer , so as to start from scratch -
    At first MCS could not find the PICKit folder, - I changed to finding it automatically, it then found the PICkit folder - but still no success.
    I also re-extracted all the PICKit2 Command Line Interface files from Microchip's site to the PICkit folder - . . .twice
    Anyway - - thanks to all - - I do not intend to "beat this to death" - - I'm perfectly content to continue doing the extra step using PICkit software separately. It works fine, and that is basically all I want.
    Thanks again
    Ken
  1. Connecting programmer to MicroCode Studio
    By KrashKaloop in forum mel PIC BASIC Pro
    Last Post: - 15th July 2014, 23:22
  2. Presetting Configuration Fuses (PIC Defines) into your Program
    Last Post: - 15th December 2013, 10:54
  3. Making Program Code Space your playground...
  4. Problem to compile my program
    By wagner in forum Off Topic
    Last Post: - 7th July 2008, 21:17
  5. Replies: 2
    Last Post: - 9th February 2006, 23:03
