Compile and Program help using PICKit2
Results 1 to 16 of 16
Threaded View
  1. #15
    Yes I found it on the Disc in it's own directory, copied it to where you said and set it up as instructed. I then ran from the command line as instructed and saw a dos window flash quickly by. Now if I run compile and program I see the dos window flash by, I do not see any activity on my programmer, this however may not be a problem as described here as I Skanked my whole windoze system the other night and am still reinstalling programs to make nice again, I may have to reinstall pickit2 too. Note to self: never delete user.dat from windows
    edit:
    OK it works, but only if I first open the PICkit2 program and select the correct chip and file first, then clicking compile and program will update the PIC firmware with 1 click. The script is copy pasted from your example. WIN98se, PBP2.50 MCS+ 3.0.0.5 . It may be a WIN98 USB issue.
  1. Connecting programmer to MicroCode Studio
    By KrashKaloop in forum mel PIC BASIC Pro
    Last Post: - 15th July 2014, 23:22
  2. Presetting Configuration Fuses (PIC Defines) into your Program
    Last Post: - 15th December 2013, 10:54
  3. Making Program Code Space your playground...
  4. Problem to compile my program
    By wagner in forum Off Topic
    Last Post: - 7th July 2008, 21:17
  5. Replies: 2
    Last Post: - 9th February 2006, 23:03
