If you're using MCS+ ICD, then you should not be trying to use the standard serialcompile for ICD ops, ICD run, then bring up the serial communicator
communicator in MCS+.
Inside the ICD window HSEROUT will display whatever you send in the lower section of
the ICD window. When it lands on an HSEROUT while running the ICD, and small serial
ICD terminal window will automatically pop-up asking for input.
I've attached a screen capture of the above running in MCS+ ICD. Tested on anCode:DEFINE LOADER_USED 1 ' using MCS+ bootloader DEFINE OSC 20 ' <-- DEFINE your OSC speed. gotta have this for MCS ICD. MyVar VAR BYTE Loop2: HSERIN [MyVar] ' <-- window pops-up waiting for input HSEROUT ["MyVar = ",DEC MyVar,13,10] '<-- displays input PAUSE 500 GOTO Loop2
18F4431.
If you still have trouble try blinking an LED with the ICD just to make sure you have
everything setup properly.
