Buying an Oscilloscope
Results 1 to 12 of 12
    Apr 2007
    Default Buying an Oscilloscope
    Hey everyone,
    I'm finally going to buy myself a PC based oscilloscope and wanted peoples' opinions before I spend a few hundred dollars on something that may not perform. I will be using it for PIC's running at 4-20MHz, serial coms from pic to pc, logic, pwm etc. as well as learning a bit more about power supplies and noise in circuits.
    I think i've narrowed it down to two:
    DSO-2090 USB - AU$349.95
    http://www.darkwire.com.au/html/dso-2090_usb.html
    Max. sample rate Realtime sampling: 100MS/s
    Bandwidth 40MHz(-3dB), Single shot bandwidth:40MHz
    - or -
    DSO-2150 USB - AU$419.95
    http://www.darkwire.com.au/html/dso-2150_usb.html
    Max. sample rate Realtime sampling: 150MS/s
    Bandwidth 60MHz(-3dB), Single shot bandwidth: 60MHz
    2 questions -
    - Will these suit what I want, or has someone found something better out there?
    - If so, is it worth the $70 difference for an extra 20MHz?
    Thank you all.
    Tom.
    Bombay, India
    Have you looked at the velleman range? I currently have a product using the PCSU1000 from them. http://www.vellemanusa.com/us/enu/pr...iew/?id=522377
    Apr 2007
    Thanks Jerson.
    Can someone briefly explain what the spectrum analysis part is for please? Is this really useful for hobby electronics?
    Here are some o'scopes with built in display and USB for scope capture.
    http://www.saelig.com/miva/merchant...._Code=PSBEB100
    When I get enough cash together, I am seriously looking at one of these units.
    Tim Barr
    Apr 2007
    Thanks, more options!
    Feb 2008
    Michigan, USA
    I have a Tek bench scope that does wonderful things as far as seeing very small details of anything that I have had the need to see, but it can't decode data streams. Ebay purchase, needs a tune-up.
    I have a Velleman HPS40 hand held and it is nice for portable work. Single channel makes it a bit limited, and it does like to feed on batteries if you don't have external power, but I DO like it. Again. this is for signal viewing, not data stream decoding.
    I had some advise from a well known magazine author and he loves his Clever Scope. At the time, I couldn't afford it, but wanted the ability to decode data streams, I tried a Saleae Logic pod for the data work and I love it @ $149. The 5 vdc input makes it limited for signal level problems, but since I already have a analog scope to see the electrical signals, the USB pod does a lot of work for me.
    Hope that helps
    Bo
    Jul 2007
    Are there any downsides to a pc based oscilloscope as opossed to a benchtop oscilloscope?
    Default re;oscilloscope
    I have been looking at the Bit Scope products. The price is a bit high and doesn't reflect the changing Euro. I am unsure about the quality of the Asian brands, although the specifications look good. Good luck.
    California, USA
    Quote Originally Posted by -Dan- View Post
    Yes. I borrowed one from a friend last year and didn't like it...
    The scope was fine, (don't remember what brand), but I HATED having my PC tied up to use the scope.
    Usually when I NEED a scope, my PC is busy. I've got a window open with schematics, a window open with board layout, one or more windows open with data sheets, and maybe MicroCode studio open as well. The LAST thing I want is something else competing for screen space on my monitor.
    Maybe if I had a dedicated PC or dual monitors on my PC it would be fine, but with my computer and work habits I *much* prefer a stand alone scope.
    There's also the issue of portability. With a laptop I guess it's no big deal, but with a desktop computer it doesn't make for a very portable scope.
    Just my opinion and personal preference. Yours may be different...
  1. Low-Cost USB Oscilloscope
    By T.Jackson in forum Schematics
    Last Post: - 16th December 2007, 14:10
  2. Analog oscilloscope - what do you think?
    By presario1425 in forum Off Topic
    Last Post: - 29th November 2007, 01:41
  3. oscilloscope
    By therian in forum Off Topic
    Last Post: - 12th March 2007, 14:38
  4. Oscilloscope MHz recomend
    By Normnet in forum Off Topic
    Last Post: - 14th May 2005, 19:58
  5. Buying an LCD Module
    By RossW in forum mel PIC BASIC Pro
    Last Post: - 10th August 2004, 16:37
