Setting up a 12F683 to run at 20 Mhz
Results 1 to 14 of 14
    Unhappy
    Quote Originally Posted by Charles Linquis View Post
    When you set
    'DEFINE OSC 20'
    You are not "telling" the chip to run at 20MHz, you are telling PBP that
    the chip is running at 20MHz (rather than 4MHz), and to adjust all pertinent
    timing accordingly.
    If the chip is actually running at 4MHz and you have DEFINE OSC 20, all the PBP PAUSES (and a lot of other timing, such as SERIN) will be off by a factor of 5. PBP uses a default define of 4MHz, so if you are actually running at 4MHz, you don't have to change this define. PAUSE 1000 will give a 1 second delay. If the PIC is actually running at 20MHz, then a PAUSE 1000 will give a 200 millisecond delay.
    If you are running at any speed other than 4MHz, then you change the define accordingly.
    Ah, makes sense.
    So in theory, if I use CFG_HS_OSC to get the 12F683 to use the external oscillator on pins 2&3 and use the DEFINE OSC 4 command...then the LED's should blink at the rate of 5X...right?
    If so, I just tried that and the rate is still X???
    What am I doing wrong?
    Better yet...How do I confirm that the chip is running at 20Mhz??
    John.
    Read this link: http://www.picbasic.co.uk/forum/showthread.php?t=543
    Setting the config statement to HS controls the power supplied to the oscillator to "enable" it to run at high speed. The crystal determines that speed, The Define statement as Charles explained Syncs up the chips internal timing to the supplied crystal and Oscon allows you to alter the oscillator's prescaler in code (more or less ).
    I'm not sure if you saw the photo I posted above...I'm using 2-27pF capacitors with the crystal. How can I confirm that the chip is running at 20Mhz?
    John.
    Sep 2005
    Campbell, CA
    Run the program below -
    Set the port to output
    TOPP:
    Toggle LED
    PAUSE 1000
    GOTO TOPP
    If the LED stays on for one second and off for one second, then
    you are running the frequency you have set in your DEFINE
    For example:
    IF have DEFINE OSC 4 -
    and the above program turns the LED one second ON and one second OFF
    Then you are running at 4MHz
    If it is on for 200milliseconds at off for 200 milliseconds. Then you are running
    at 20MHz.
    Charles Linquist
    Angry
    TOPP:
    Toggle LED
    PAUSE 1000
    GOTO TOPP
    For example:
    at 20MHz.
    I kinda thought that's what I had to do...just didn't believe it was that simple!
    So I did that...even though I've 'told' the chip to run the external crystal and defined osc 4...I'm not blinking @ 200ms
    Either the crystal isn't oscillating properly...or I should start flippin' burgers
    BTW: The reason I'm trying to run this 12F683 at 20Mhz is to obtain readings from an accelerometer (aboard an RC aircraft) and control 3 servos all in a relatively smooth way.
    In addition, I've bought XBEE 900 Mhz XSC transceivers and will be passing telemetry information from the aircraft to a ground station. I have more Q's about serial communications from the 12F683 to the XBEE...but that's for another thread. I first have to figure out what I don't know.
    Cheers,
    JOhn.
    It does not look like you are setting the config correctly.
    The thread that Joe and I pointed you to should have helped.
    For now try going to the inc file for this chip in the PBP directory. Below is part of it.
    If you are using PM for the assembler change
    device pic12F683, intrc_osc_noclkout, wdt_on, mclr_on, protect_off
    to
    device pic12F683, hs_osc, wdt_on, mclr_on, protect_off
    If you are using MPASM then change
    __config _INTRC_OSC_NOCLKOUT & _WDT_ON & _MCLRE_ON & _CP_OFF
    to
    __config _HS_OSC & _WDT_ON & _MCLRE_ON & _CP_OFF
            XALL
            NOLIST
            LIST
            LIST p = 12F683, r = dec, w = -302
            INCLUDE "P12F683.INC"	; MPASM  Header
    to
    to
    Dave, thanks for your help, really appreciate it. I've been spending too many hours (very unproductive ones at that) trying to learn this thing called picbasic, and, as I'm sure you know, after you hit that frustration level...YOU JUST CAN'T GIVE UP! And, of course its down hill from there...Sleep is good, if you can get your mind off the problem.
    Anyway,
    Here's my Code:
    [HTML]@__config _HS_OSC & _WDT_ON & _MCLRE_ON & _CP_OFF
    DEFINE OSC 20
    CMCON0 = 7 ' Analog comparators off
    ANSEL = 0 ' Analog select set to digital, pg 69 data
    ADCON0 = 0 ' A/D turned OFF, pg 68 of data
    'Define Variables
    'Set Variables
    low 0
    start:
    toggle 0
    goto start
    end[/HTML]
    When I change the DEFINE OSC between 4, 8, 20 it seems to work fine now...but I get compilation errors as follows:
    [HTML]Executing: "C:\PBP\PBPW.EXE" -ampasmwin -oq -z -p12F683 "Blink 12f683 simple.bas"
    PICBASIC PRO(TM) Compiler 2.50b, (c) 1998, 2008 microEngineering Labs, Inc.
    All Rights Reserved.
    Warning[205] E:\USERS\JDROOG\DOCUMENTS\MCS\BLINK 12F683 SIMPLE.ASM 82 : Found directive in column 1. (__config)
    Error[118] E:\USERS\JDROOG\DOCUMENTS\MCS\BLINK 12F683 SIMPLE.ASM 82 : Overwriting previous address contents (2007)
    Loaded E:\Users\jdroog\Documents\MCS\Blink 12f683 simple.COD.
    BUILD SUCCEEDED: Mon Mar 02 19:14:43 2009[/HTML]
    What exactly does this mean??
    John.
  1. PICKit2 - warning about configuration words
    Last Post: - 4th August 2009, 14:01
  2. Char. LCD and 18F452 on 20 MHz not work
    By samettin in forum General
    Last Post: - 28th July 2008, 09:59
  3. PIC18F2685 config settings for 20 MHz
    By wwilson17 in forum mel PIC BASIC Pro
    Last Post: - 31st March 2008, 23:13
  4. 20 MHz + PLL vs 48MHz
    By Demon in forum General
    Last Post: - 31st July 2006, 12:02
  5. How to use a 20 MHz resonator on a 16F688
    By Thomas Williams in forum mel PIC BASIC Pro
    Last Post: - 21st December 2005, 09:18
