Setting up a 12F683 to run at 20 Mhz
Results 1 to 14 of 14
Threaded View
  1. #3
    _HS_OSC
    Needs to be used in the configs.
    Then
    DEFINE OSC 20
    needs to be near the top of your code.
    Have you read this thread?
    I just looked at the link...Great information! Thanks for that.
    I'll try your suggestions above today, really appreciate that too.
    Do you know if the crystal and capacitor setup is 'touchy'? I'm trying to paste an image of the setup here...but not sure if you'll see it...
  1. PICKit2 - warning about configuration words
    Last Post: - 4th August 2009, 15:01
  2. Char. LCD and 18F452 on 20 MHz not work
    By samettin in forum General
    Last Post: - 28th July 2008, 10:59
  3. PIC18F2685 config settings for 20 MHz
    By wwilson17 in forum mel PIC BASIC Pro
    Last Post: - 1st April 2008, 00:13
  4. 20 MHz + PLL vs 48MHz
    By Demon in forum General
    Last Post: - 31st July 2006, 13:02
  5. How to use a 20 MHz resonator on a 16F688
    By Thomas Williams in forum mel PIC BASIC Pro
    Last Post: - 21st December 2005, 10:18
