Darrel's interrupts in a 7 segment display
Results 1 to 17 of 17
    Default Darrel's interrupts in a 7 segment display
    I have a design with a 3 digit 7 segment multiplexed display that showed a certain value. The circuit and the code worked fine while the display was about the only thing the PIC had to do.
    Now, I tried to use Darrel's "DT_INTS-14.bas" as I need a few other things done in the code as well.
    The chip is a 16F887.
    My observations; the display flickers a lot; changing the prescaler to 1:1 is still bad, but better than other settings. Pre-loading TMR1 with any value seems to have no effect.
    What am I doing wrong?
    ANSEL = 0
    ANSELH = 0
    CM1CON0.7 = 0
    CM2CON0.7 = 0
    TRISA = 0
    TRISB = 0
    TRISC = 0
    TRISD = 0
    TRISE = 0
    N VAR BYTE
    SEGDEF VAR BYTE
    INCLUDE "DT_INTS-14.bas" ' Base Interrupt System
    INCLUDE "ReEnterPBP.bas" ' Include if using PBP interrupts
    INT_Handler TMR1_INT, _DISP, PBP, yes
    T1CON = $1
    ; Prescaler = 8, TMR1ON
    @ INT_ENABLE TMR1_INT ; enable Timer 1 interrupts
    TMR1H = %11111111
    TMR1L = %11110111
    toggle stat_LED
    GOTO Main
    DISP: N = 1
    GOSUB BIN2SEG
    PORTC = SEGDEF
    PORTE = 6
    PAUSE 3
    N = 2
    GOSUB BIN2SEG
    PORTC = SEGDEF
    PORTE = 5
    PAUSE 3
    N = 3
    GOSUB BIN2SEG
    PORTC = SEGDEF
    PORTE = 3
    PAUSE 3
    @ INT_RETURN
    BIN2SEG:LookUp n,[132,175,193,137,170,152,144,143,128,136,210,251],SEGDEF
    Blinky?? No doubt!
    Assuming a 4Mhz OSC, your interrupt frequency is ~15Hz (~65.5ms).
    Then each digit is shown for ~3ms for a total of 9ms out of that 65.5.
    With the third digit left ON, that one's probably very bright.
    For one, you need to reload the Timer in the Interrupt Handler, not the Main loop.
    The interrupt frequency should be at least 300Hz, 1Kz is better.
    DISP:
      T1CON.0 = 0     ; stop timer
      TMR1H = %11111100
      TMR1L = %00011111
      T1CON.0 = 1     ; restart timer
    And in the handler, only turn on 1 digit per interrupt. Don't pause, don't gosub.
    Default Don't pause, don't gosub
    ahhhh, there's the kick i needed.
    I also am working on a 3digit 7seg led display, using modified code
    (read: massively mangled stolen code :P)
    and was doing the same thing..
    (pausing, and calling/gosubing the bin2seg lookup)
    MOVF _led1data,W
     call bin2seg
     MOVWF PORTD
     bsf _led1digit
     call dly7seg
     bcf _led1digit
     movf _led2data,W
     call bin2seg
     movwf PORTD
     bsf _led2digit
     call dly7seg
     bcf _led2digit
     movf _led3data,W
     call bin2seg
     movwf PORTD
     bsf _led3digit
     call dly7seg
     bcf _led3digit
    so some ideas i was wrestling with just got answered?..
    1)thinking should look digits up in the main loop? and use the already "lookedup" variables in the interupt routine.
    2)now the one digit per interrupt, I had thought about, but couldn't figure out how to do. (put on back burner, until I saw this)
    little trickier.. without a gosub?
    would something like this work? (seems long way no?)
    if digitloop=3 then digitloop=0 'only three digits
    digitloop=digitloop+1             'next digit
    if digitloop=1 goto digit1        'which digit we displaying?
    if digitloop=2 goto digit2
    digit3:                                'wasn't 1 or 2 so must be 3!
    PORTC = SEGDEF3                'output "prelookedup" data
    PORTE = 3                          'turn digit on
    goto dispdone                     'goto finish
    digit2:                                'doing digit 2
    PORTC = SEGDEF2                'output "prelookedup" data
    PORTE = 5                          'turn digit on
    digit1:                                'doing digit1
    PORTC = SEGDEF1                'output "prelookedup" data
    PORTE = 6                          'turn digit on
    DISPDONE:                             'reload timer
      TMR1H = %11111100
      TMR1L = %00011111
    @ INT_RETURN                         'exit int routine
    on the right track?
    should the timer be stopped at the beginning of the routine?
    now in the main, will we need 3 lookup tables? can lookup into an array? or how about...
    n=1                        'to be replaced with digit1 variable (N=N1)
    gosub bin2seg
    segdef1=segdef
    n=2                        'digit2
    gosub bin2seg
    segdef2=segdef
    n=3                       'digit3
    gosub bin2seg
    segdef3=segdef
    BIN2SEG:
    (I was attempting mine in assembly, but so as not to hijack the thread, did this way)
    You guys always make me hungry. I LOVE spaghetti.
    Just not in my code.
      FOR Value = 0 TO 999
        GOSUB SetDisp
        PAUSE 500
      NEXT Value
    GOTO Main
    '---[Set 7-seg patterns to WORD value]--------------------------------------
    SetDisp:
      FOR Idx = 2 to 0 STEP -1
        Temp = Value DIG Idx
        LookUp Temp,[132,175,193,137,170,152,144,143,128,136,210,251],Temp
        SEGDEF(Idx) = Temp
      NEXT Idx
    '---[TMR1 - interrupt handler]----------------------------------------------
    DISP:
      TMR1H = %11111100
      TMR1L = %00011111
      PORTE = %111                 ; turn off all digits to prevent ghosting
      PORTC = SEGDEF(digitloop)    ; put segment pattern to pin
      PORTE = ~(DCD digitloop)     ; turn on the digit
      digitloop = digitloop + 1    ; prepare for next digit
      IF digitloop = 3 then digitloop = 0
    @ INT_RETURN
    Completely untested ...
    WOW... how simple to put the digitloop at the end, MUCH cleaner. less if'ing
    was looking at it backwards lol , maybe I should try standing on my head..
    and I started to do a loop (for) deal, but cant use val(x) in the lookup, and went all off the other way. lol.. shoulda figured out/stuck with the original idea.
    THANKS! looks shweet cant wait to test
    Think you solved both our problems!
    Default Worked! now, another (sub)problem
    Wow, worked the first time, Darrel.
    Now, if I want to bit bang (I've already commited the hardware UART to something else) a couple of parameter values over the serial port, where in the code you've shown would the line go?
    I've been struggling with this, with no success; or is this normal when one is using TMR0?
    Anand
    [QUOTE=ardhuru;70828]; or is this normal when one is using TMR0?
    /QUOTE]
    Sorry, TMR1, I mean.
    Great! I guess my internal simulator is still working.
    If it's only a couple values every now and then, just turn off the interrupts before using the SEROUT? statement.
    Depending on the baudrate and amount of data, it may cause a small blink in the display.
    Sep 2005
    Campbell, CA
    If you set your interrupt time to 1.5mSec or so, you can send one character at 9600 baud between interrupts. Just don't try to do too much else in that period!
    Charles Linquist
    Feb 2008
    Michigan, USA
    Default Re: Darrel's interrupts in a 7 segment display
    Hi all,
    I'm having trouble understanding something in this example code. Maybe someone can explain.
        GOSUB SetDisp
        PAUSE 500
      NEXT Value
    GOTO Main
    SetDisp:
        SEGDEF(Idx) = Temp
      NEXT Idx
    The biggest question is why is there 12 data points in the table? I am assuming that the actual numbers are because of the wiring of the digits with this specific LED as I can not figure out a segment pattern. After that, I fall down on why 12 instead of 8 unless it involves positioning the decimal point somehow. I wonder, if with the original wiring, this would be clearer to me. I would think that you would line up the segments in order with the port pins in order.
    Mark
    Feb 2008
    Michigan, USA
    Another observation that this is a specific solution to the OP's issue is that can't be just cut-n-pasted without thinking it through:
    my application is common cathode and it uses a ULN2803 as a driver for the cathodes of the digits. If I hadn't looked at it and tried to understand it, I could have easily have turned on ALL BUT ONE of the displays instead of ONE AT A TIME. Mine is also, 8 digits, so it matters a bit more for the PIC pin. Not a complaint in any way, more of a way to close the loop for anyone looking at it later. BTW: very slick way to step through the digits. Learned something new today.
    Mark
    Jun 2009
    Sc*nthorpe, UK
    Quote Originally Posted by boroko View Post
    Hi all,
        GOSUB SetDisp
        PAUSE 500
      NEXT Value
    GOTO Main
    SetDisp:
        SEGDEF(Idx) = Temp
      NEXT Idx
    Mark
    As I can not resist a challenge even if it is only an academic exercise to me.
    ------- GFEDCBA
    0 132 10000100
    1 175 10101111
    2 193 11000001
    3 137 10001001
    4 170 10101010
    5 152 10011000
    6 144 10010000
    7 143 10001111
    8 128 10000000
    9 136 10001000
    F 210 11010010
    - 251 11111011
    Looking at the bit pattern for :-
    0 the active segments are 0 and inactive 1 in a 0 the central cross bar is inactive therefore this is C
    6 the only inactive segment is top right therefore this is E
    5 the inactive segments are top right and bottom left so bottom left is D
    9 confirms bottom left is D
    3 top left and bottom left inactive so top left is A
    2 top left and bottom right inactive so bottom right is G
    7 top left centre bottom left and bottom inactive so bottom is B
    which leaves F is the top segment giving this pattern
    -F-
    A E
    -C-
    D G
    -B-
    251 is the centre bar obviously used for - (minus)
    210 converting the bit pattern gives F
    Having decoded this pattern it makes no sense to me as the normal segment pattern is
    Leaving the question why connect a 7 segment display in this no standard way?
    Well Actually Steve, The display's may have been wired that way in the schematic originally. Makes no difference. As far as the table is concerned, to generate all 16 hexidecimal characters the table would be 16 entries wide. in the past I have generated tables with all 16 entries as well as lower case "c,n o r". Thats 20. Ther is no standard way if you get my drift. It's completely up to the circuit designer.
    EN82fn
    Jun 2009
    Sc*nthorpe, UK
    In my post I decoded the lookup table to work out the display pattern and the wiring. I intuitively did not like the resultant pattern and wondered why choose that pattern. Internet searches revealed a commonly followed trend of port.0-port.7 connected to a-g respectively.
    From Wikipedia
    LED-based 7-segment display which cycles through the common glyphs of the ten decimal numerals and the six hexadecimal "letter digits" (A–F)
    Hexadecimal digits can be displayed on seven-segment displays. A combination of uppercase and lowercase letters is used for A–F;[6] this is done to obtain a unique, unambiguous shape for each hexadecimal digit (otherwise, a capital D would look identical to an 0 and a capital B would look identical to an 8). Also the digit 6 must be displayed with the top bar lit to avoid ambiguity with the letter b.
    Which implies that there are two ways to wire up a seven segment display one for g-a encoding and one for a-g encoding. But as you say no one has to follow these commonly used encodings, which do dictate the circuit to be used.
    The inclusion of "-" and "F" in the encoding makes me think that the original code was probably for displaying temperatures. Also the codes are eight digits which includes the DP reinforcing the idea of a temperature display. I wonder if the original project was wired in the same way, that is assuming this is recycled code.
    Can anyone see any advantage in this scheme?
    -F-
    A E
    -C-
    D G
    -B-
    I can not and surely the wiring will be like spaghetti.
    most obvious reason would be to make the easiest possible (construction wise ) homebrew pcb layout . ie reduce the need for a ds board or even just minimise via's
    Jun 2009
    Sc*nthorpe, UK
    Yes it just has me wondering as I can not see any obvious benefit. As I will never use these I am going to stop worrying about it.
    Feb 2008
    Michigan, USA
    intriguing discussion, but you're right... a rabbit trail. Mine works, I'm moving on.
    Mark
  1. 7 Segment Displays and MAX7219
    By Bill Legge in forum mel PIC BASIC Pro
    Last Post: - 31st October 2010, 18:30
  2. LED Machine Tach For Tired Eyes
    By Archangel in forum mel PIC BASIC Pro
    Last Post: - 27th January 2010, 14:55
  3. Weird compile issue 7 segment LED display
    By George in forum mel PIC BASIC Pro
    Last Post: - 21st June 2006, 02:12
  4. 7 segment digit problem (using Mister E's code)
    By jmgelba in forum mel PIC BASIC Pro
    Last Post: - 9th September 2005, 20:25
  5. WRITE not working
    By servo260 in forum mel PIC BASIC Pro
    Last Post: - 29th December 2004, 02:02
