Analog input problem
Results 1 to 13 of 13
    Sep 2008
    my pic is 16f877a
    Sep 2008
    ı wrote this code.
    What i see on lcd is the values getting bigger .Started 90,100,108,120,145
    How can i use first analog five input pins in 16f877a...
    DEFINE LCD_DREG PORTB
    DEFINE LCD_DBIT 0
    DEFINE LCD_RSREG PORTB
    DEFINE LCD_RSBIT 4
    DEFINE LCD_EREG PORTB
    DEFINE LCD_EBIT 5
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    DEFINE ADC_BITS 8
    DEFINE ADC_CLOCK 3
    DEFINE ADC_SAMPLEUS 100
    SYMBOL VERI=PORTA.5
    deneme var byte
    ADCON1=10000010
    TRISA=%11111111
    basla:
    LCDOUT $FE,1
    adcin veri,deneme
    LCDOUT $fe,2,#deneme," "
    pause 3000
    goto basla
    which setting is wrong ???
    1. you have to set trisa.5 to 1, make this pin as input
    2. choose an ADCON1 setting that set AN4 as analog, =0 or =2 have to work
    3. make sure analog comparator is disable. CMCON=7
    4. use ADCIN with analog channel number, not his pin name
    ADCIN 4, YourVariable
    HTH
    Sep 2008
    I wrote this but same problem continues.the value starts 111 gets bigger and bigger up to about 249-254
    DEFINE LCD_DBIT 0
    DEFINE LCD_RSBIT 4
    DEFINE LCD_EBIT 5
    DEFINE LCD_BITS  4
    DEFINE LCD_LINES 2
    DEFINE ADC_BITS     8
    DEFINE ADC_CLOCK  3
    deneme var byte
    ADCON1=2
    trisa.4=1
    CMCON=7
    basla:
    LCDOUT $FE,1
    adcin 4,deneme
    pause 3000
    goto basla
    try ADCON1=%11100010
    Sep 2008
    i tried this it worked !
    deneme var byte
    ADCON1=0
    trisa.5=1
    CMCON=7
    basla:
    LCDOUT $FE,1
    adcin 4,deneme
    pause 3000
    goto basla
    after that i tried this it didnt work
    values is getting smaller now..
    its so weird
    bilgi var byte
    red var byte
    green var byte
    blue var byte
    ADCON1=0
    trisa.5=1
    trisa.1=1
    trisa.2=1
    trisa.3=1
    trisa.0=1
    CMCON=7
    TRISB=0
    PORTB=0
    TRISC=0
    TRISD=0
    LCDOUT $FE,1
    yap:
    high PORTD.7
    PAUSE 750
    ADCIN 5,bilgi
    red=bilgi
    pause 5
    low PORTD.7
    high PORTD.6
    PAUSE 750
    ADCIN 5,bilgi
    blue=bilgi
    pause 5
    low PORTD.6
    high PORTD.5
    PAUSE 750
    ADCIN 5,bilgi
    green=bilgi
    pause 5
    low PORTD.5
    CALL GOSTER
    pause 7000
    goto yap
    GOSTER:
    LCDOUT $fe,2,#red," ",#blue," ",#green," "
    Where am i wrong this final code???
    In the first you have ADCIN 4, the second you have ADCIN 5.
    What is your analog source? Any available schematic ?
    You want to use GOSUB instead of CALL. don't forget the RETURN as well.
    Sep 2008
    sorry. i put code there imcomplete.there is a "return" at the end.i saw this picture .there is RA5 after RA3.thats why i used porta.5.do you have any idea why did it work with first code and didnt with second???
  1. PIC16F877A analog problem
    By DeViLa_Q8 in forum mel PIC BASIC
    Last Post: - 30th July 2009, 20:19
  2. pic18f analog comparator problem
    By david.silaghi in forum mel PIC BASIC Pro
    Last Post: - 6th May 2009, 09:38
  3. Analog Input on PIC16F88
    By penelopepug in forum mel PIC BASIC Pro
    Last Post: - 6th May 2008, 22:49
  4. problem with input and output (18F452)
    By turkuaz in forum mel PIC BASIC Pro
    Last Post: - 17th March 2008, 23:21
  5. 16C55 Problem.
    By hope_man in forum mel PIC BASIC Pro
    Last Post: - 18th March 2006, 16:15
