How i can use the tcs230 with pic
Results 1 to 3 of 3
    May 2008
    Italy
    This snipet has been copied from parallax and should work with pic. Use 4MHz resonator or change Define setting if different clock will be used.
    Define OSC = 4
    DEFINE HSER_SPBRG 25  ' 9600 Baud @ 4MHz, 0,16%
    EN con 1
    A0 con 2
    S0 con 3
    S1 con 4
    S2 con 5
    S3 con 6
    nLED con 7
    pRED con 12
    pGREEN con 6
    pBLUE con 5
    Pinx  var (pic pin connected to the output)
    RED var word
    GREEN var word
    BLUE var word
    Start: low A0
    high S0
    high S1
    low nLED
    high EN
    MainLp: gosub Color
    debug "R", dec3 RED
    debug " G", dec3 GREEN
    debug " B", dec3 BLUE
    debug cr
    goto MainLp
    Color: low S2
    low S3
    count pinx, pRED, RED
    high S3
    count pinx, pBLUE, BLUE
    high S2
    count pinx, pGREEN, GREEN
    Al.
    buketselen's Avatar
    buketselen Guest
    Default Re: How i can use the tcs230 with pic
    : ı wonder the same question with you.ıf you succed your project could you send me it too.
  1. SMS via pic
    By kenandere in forum GSM
    Last Post: - 10th March 2010, 11:00
  2. Replies: 67
    Last Post: - 8th December 2009, 03:27
  3. HSERIN & Interupts (aka controlling PIC programs from a remote PC)
    Last Post: - 17th June 2009, 15:46
  4. pic to pic ir link versus wired link : help please anyone
    Last Post: - 30th May 2008, 22:01
