[212] extra tokens error 12F629
Results 1 to 3 of 3
    jswayze's Avatar
    jswayze Guest
    Default [212] extra tokens error 12F629
    I'm trying to create a "lite" version of software originally written for a 16F628A and use it with a 12F629. Using MicroCode Studio, I'm encountering an error that appears to have little documentation:
    Assembler error: [212] extra tokens on end of line
    The line in question is a simple "END SELECT" statement.
    Can anyone shed light on this error?
    Thanks!
    -Jeff
    Will be hard to have the great answer since we don't see your code BUT
    • 1. is your SELECT CASE refer to i/o pins ? Be sure you use GPIO instead of PORTx
      2. about TRIS .... TRISIO instead of TRISx..
    and such ... be sure you're using the right Register, Port name for the according PIC.
    jswayze's Avatar
    jswayze Guest
    Default New strange problem... Help!
    Thanks Steve,
    I had an "@" directive at the head of my code that seemed to mess things up. I commented it out and the error went away.
  1. Error: extra tokens on end of line
    By Jasonce65 in forum mel PIC BASIC Pro
    Last Post: - 23rd January 2008, 18:04
  2. Disable MCU Extra Features
    By cjurczak in forum General
    Last Post: - 17th November 2006, 18:51
