Internal oscillator please help
Results 1 to 10 of 10
    It even runs if I set it for external oscillator
    That's a big red flag there. Are you 100% sure you're even programming it?
    If you set config options for an external crystal or resonator, program the part,
    and it's still running, you really do have a problem.
    Post all your code & let us know which programmer you're using. That would really
    help.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Feb 2009
    This is all I have, at this point I was just trying to get the thing to do something in this case the leds on the different ports do switch on and off.
    @ Device PWRT_OFF
    @ Device MCLR_OFF
    @ Device INTRC_OSC
    @ Device BOR = 0
    @ Device Debug_Off
    OSCCON = %01110000
    OPTION_REG = %11111111
    TRISB = %00101010
    loop:
    TRISB = %00101010
    Pause 1
    PortB = 1
    TRISB = %11010101
    Pause 1
    PortB = 1
    TRISB = %00101010
    Pause 1
    goto loop
    Indeed there's a problem, the above don't set the proper config fuses.
    Try
    @   device pic16f819, INTRC_OSC_NOCLKOUT
    @   device pic16f819, WDT_OFF
    @   device pic16f819, PWRT_ON
    @   device pic16f819, MCLR_OFF
    @   device pic16f819, BOD_ON
    @   device pic16f819, LVP_OFF
    @   device pic16f819, DEBUG_OFF
    That line you had
    @ Device BOR = 0
    screw everything up
    You might want DEFINE OSC 8 in there too if you're running at 8MHz VS the default 4MHz.
    -Bruce
    tech at rentron.com
    Feb 2009
    Well Steve, that seems to have done it Thank You!!! I'm not sure I quite understand it all but I can work it out I'm sure.
    Thanks again.
    Hi Tim. Maybe this will help you. I believe the following also applys to the 16F88.
    'INTERNAL OSCILLATOR VALUES for 16f818/819:
    'OSCCON = $00 'for 31.25 khz
    'OSCCON = $10 '125khz
    'OSCCON = $20 '250khz
    'OSCCON = $30 '500khz
    'OSCCON = $40 '1mhz
    'OSCCON = $50 '2mhz
    'OSCCON = $60 '4mhz
    'OSCCON = $70 '8mhz
    adcon1 = 7 ' set inputs to digital. Using the adcin command will automatically convert the ADC port to 'analog
    'OPTION_REG.7=0 ' Switch-ON weak pull-up's on portb
    '@ DEVICE MCLR_ON, INTRC_OSC, WDT_ON, LVP_OFF, BOD_OFF, PWRT_ON, PROTECT_ON
    'CCPMX_ON THE @ DEVICE LINE ABOVE SETS HPWM OUTPUT TO RB3, CCPMX_OFF (DEFAULT IF NOT 'SPECIFIED) = RB2
  1. Internal vs. external osc for comms
    By mtripoli in forum mel PIC BASIC Pro
    Last Post: - 29th January 2010, 14:58
  2. 12F683 internal pull up
    By hvacrtech in forum mel PIC BASIC Pro
    Last Post: - 27th July 2008, 02:35
  3. PIC18F4620 Using the Internal Oscillator
    By kiwipiper in forum mel PIC BASIC Pro
    Last Post: - 23rd October 2007, 08:07
  4. Use internal program memory like DATA memory
    Last Post: - 30th December 2006, 18:38
  5. PIC12F675, accuracy of baud rate with Internal Oscillator
    By Chris Mayhew in forum mel PIC BASIC Pro
    Last Post: - 31st August 2005, 22:41
