Internal oscillator please help
Results 1 to 10 of 10
    Feb 2009
    Default Internal oscillator please help
    I've been trying for a day and a half now to get my PIC to do something I finally have it running but it is running slow. If I put pause 1000 in the code it basically stops. When I do pause 1 it runs at about 4Hz but speeds up if I put my finger near the pic. Whatever changes I make to Internal oscillator speeds it stays at the same speed. It even runs if I set it for external oscillator. I don't understand. Here's the code I have.
    @ Device PWRT_OFF
    @ Device MCLR_OFF
    @ Device INTRC_OSC
    @ Device BOR = 0
    @ Device Debug_Off
    OSCCON = %01110000
    OPTION_REG = %11111111
    TRISB = %00101010
    Any help would be appreciated.
    Which Pic, please ...
    Dec 2006
    WADSWORTH OHIO USA
    Smile
    RTDS is the answer...
    Refer To Data Sheets
    Thanks !
    SOMRU
    TWE/TFP/EE
    Feb 2009
    Sorry, 16F819
    I've been over the datasheets time and time again and cannot figure this out.
    That's a big red flag there. Are you 100% sure you're even programming it?
    If you set config options for an external crystal or resonator, program the part,
    and it's still running, you really do have a problem.
    Post all your code & let us know which programmer you're using. That would really
    help.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Feb 2009
    This is all I have, at this point I was just trying to get the thing to do something in this case the leds on the different ports do switch on and off.
    @ Device PWRT_OFF
    @ Device MCLR_OFF
    @ Device INTRC_OSC
    @ Device BOR = 0
    @ Device Debug_Off
    OSCCON = %01110000
    TRISB = %00101010
    loop:
    TRISB = %00101010
    Pause 1
    PortB = 1
    TRISB = %11010101
    Pause 1
    PortB = 1
    TRISB = %00101010
    Pause 1
    goto loop
  1. Internal vs. external osc for comms
    By mtripoli in forum mel PIC BASIC Pro
    Last Post: - 29th January 2010, 14:58
  2. 12F683 internal pull up
    By hvacrtech in forum mel PIC BASIC Pro
    Last Post: - 27th July 2008, 02:35
  3. PIC18F4620 Using the Internal Oscillator
    By kiwipiper in forum mel PIC BASIC Pro
    Last Post: - 23rd October 2007, 08:07
  4. Use internal program memory like DATA memory
    Last Post: - 30th December 2006, 18:38
  5. PIC12F675, accuracy of baud rate with Internal Oscillator
    By Chris Mayhew in forum mel PIC BASIC Pro
    Last Post: - 31st August 2005, 22:41
