Interfacing DS1603 to PIC 16F877
Results 1 to 5 of 5
    Feb 2009
    Default Interfacing DS1603 to PIC 16F877
    Hi.
    I'm new here to the forum so apologise for jumping in straight away with a question.
    I have spent a few months playing with PIC's and have learnt enough now to create a system to control the various devices installed in my caravan. My most recent example is a 16F628 based 'Autofill' water tank level controller with LCD readout of tank levels.
    For my next project, I plan to use a 16F877 with a menu to control various devices whilst at the same time displaying the charge state of the auxiliary batteries and the time & date on a 4 x 20 LCD display.
    I have completed a program including a menu to monitor battery voltages etc and display them all on the LCD but my problem is IF try to include a piece of code which keeps track of time I feel it will not be accurate enough while the PIC is away completing other tasks it will affect the timekeeping section of the program.
    I have scraped around and found a part in the junk box "DS1603" for which the Data sheet can be found HERE which appears to keep track of time for me but I have no idea how to interface this device nor have I any idea how to create the software algorithm which the data sheet states will be required.
    Has anyone ever dealt with this part before "DS1603" or can anyone point me in the right direction on interfacing this device and creating the correct software to read/write it? Then converting it to a usable string ready to print on an LCD? An example would be great as I have learnt more from reading other peoples code and trying to understand it. I find datasheets often help but they confuse the hell out of me at times.
    Fingers crossed.
    Paul.
    Probably you don't need it at all. Do a search for Elapsed Timer Demo and Olympic Timer in this forum.
    http://www.picbasic.co.uk/forum/showthread.php?t=190
    http://www.picbasic.co.uk/forum/showthread.php?t=632
    HTH
    Feb 2009
    Hey, Thanks for the very quick reply, I'm having a read up on it now.
    Sep 2005
    Campbell, CA
    Just a suggestion - if you are making a whole bunch of neat little projects, I'd stick with the 18F family. They offer a lot of advantages and don't cost that much more.
    Charles Linquist
    Feb 2009
    Quote Originally Posted by Charles Linquis View Post
    I have heard that a few times from a few people. I have a few 16F type available at the moment but when I've used them all up I might look into buying the 18F's next.
  1. how can I make 1 wire between two pic 16f877
    By povulon in forum mel PIC BASIC Pro
    Last Post: - 30th July 2008, 15:44
  2. SPI Communication between two pic 16f877
    By anti83 in forum Serial
    Last Post: - 5th July 2008, 22:06
  3. Interfacing two PIC micros
    By sajid in forum General
    Last Post: - 26th May 2007, 07:58
  4. serial communication between CMUcam and PIC 16F877
    By gengkeys in forum mel PIC BASIC Pro
    Last Post: - 30th March 2007, 07:43
  5. Use the PIC 16f877 or 877A instead of shift registers.
    By tsanders in forum mel PIC BASIC Pro
    Last Post: - 27th October 2006, 18:23
