Will PBP work in Vista64?
Results 1 to 13 of 13
    At least on my vista 32 is ok. I really love to hear about 64.
    I would suggest you to submit a ticket to Melabs tech support. They're really kind and answer pretty fast. Probably they know a workaround?
    [email protected]
    Yes, it is working on my 64 bit Vista with Micro Code Studio Plus.
    Out of curiosity, at your first post did you used MPLAB or what? If it's MPLAB 8.2, you may have some problem indeed, but it's not a Melabs issue, you may try MPLAB 8.15, which is available on Melabs website.
    Feb 2009
    Pyrénées Audoises, France
    Hi Steve,
    I do have MPLAB 8.10 installed on the machine but what effect does that have? I downloaded the demo and it (just) installed 'MicroCodeStudio' and (I guess) the PICBASIC demo stuff. No mention was made of having to have 'MPLAB' already installed.
    Confused R us!!
    If I'm right, and as per your error message, PM assembler is build in 16 bit, and Vista 64 can't cope with 16 Bits. MPASM assembler (which come with MPLAB) should be build in 32 bits, this is something Vista 64 should handle.
    Well, that's my own and personal understanding of it. I never use PM as assembler, but MPASM.
    I guess one day Melabs may release PM in 32bits, or just suggest to use MPASM instead OR have MPASM installed in.
    In MicroCode Studio, click on View > Compile and program option >> Assempler and check 'use MPASM' box. That should do the trick... finger crossed.
    Feb 2009
    Hi Steve,
    It worked (I think)! I carried out your suggestion and the prog went off and found 'MPASM'. It couldn't find my programmer though (PICkit 2) but I guess that this is a seperate issue. I loaded one of the demo files and, after I made a few changes and re-named it, it went off and generated an 'asm' file. This opened fine in MPLAB IDE.
    If 'PM.exe' doesn't work and I am using 'MPLAB' to generate code do I actually need to buy 'PICBASIC' or merely 'MicroCode Studio'? There's a big difference in price!!
    Many thanks for your patient help, it is greatly appreciated.
    Cheers.
    You can use MicroCode Studio free version. Unless you purchase a specific bundle, PICBasic Pro compiler come with the Free Version of MicroCode Studio. MicroCode Studio is just the code editor.
    MicroCode Studio PLUS offer the ICD feature + Bootloader firmwares. To start, you may don't need those feature.
    You could still do everything in MPLAB if you want, but still you need to buy PICBASIC compiler. MPLAB have some feature that MicroCode Studio don't have. On the Other hand, MicroCode Studio have some feature that MPLAB don't have, first one being Serial communicator + Ability to add a new programmer with command line.
    In MicroCode Studio, you want to manually point the IDE to your MPASM installation folder. usually c:\program files\MicroChip\Mpasm suite
    Same thing when you add a third party programmer such as PICFlash, PICKIT 2 and so on.
    Now if you hesitate between PICBASIC and PICBASIC PRO... if you have the cash for PICBASIC PRO, then do it, it will save you load of headaches.
    Feb 2009
    Interesting! My copy of 'MicroCode Studio' launches fine and it is only when I click on 'compile program' that I get the error as attached. Did the programme work 'out of the box' in Vista64 for you?
    Cheers.
    try using MPASM as assembler to see what happen.
  1. ICD & PBP && how to get it to work
    By archendekta in forum mel PIC BASIC Pro
    Last Post: - 24th March 2010, 02:56
  2. How to set ICD-2 clone to work with PBP?
    By G-R-C in forum mel PIC BASIC Pro
    Last Post: - 20th October 2006, 03:50
    Last Post: - 2nd May 2006, 20:01
  4. Pin RA4 doesn't work
    Last Post: - 15th July 2004, 13:03
  5. PBP "USART.BAS" Doesn't Work
    By Corey in forum mel PIC BASIC Pro
    Last Post: - 21st October 2003, 13:29
