pin compatible pic for 16C58
Results 1 to 3 of 3
    Default pin compatible pic for 16C58
    hello
    i'm work with the melabs serial programmer and i want to replace a pic16c58 in a existing environment.
    does anyone know a pin compatible typ for the 16c58 (18pin dip) which can be programmed with the melabs serial programmer?
    thanks a lot
    As i know, every 18pins package are pin to pin compatible. the only diference will be in the internal capability (a/d, memory, USART, etc)
    PIC16c622, PIC16c71X, PIC16F628, 16F819 are good choice depending what you want to do with... The best way to know what will fit to your application, see the Microchip website under the Microcontroller section OR Melabs product selector http://melabs.picbasic.com/Scripts/perl/picsearch.pl
    Default I know this is old but
    No, the 18 pin devices are not all pin for pin compatible. the 16c717 has only half in common with a 16f628 or 16f84. thought i'd post this just in case.
  1. DS1820 with 16f688
    Last Post: - 23rd May 2009, 06:07
  2. make a low voltage output from a PIC pin
    By emptyset in forum General
    Last Post: - 8th February 2008, 20:20
  3. Can a PIC PIC a PIC?
    By afbecker in forum mel PIC BASIC Pro
    Last Post: - 22nd January 2008, 20:55
  4. Another RTC, DS1287
    Last Post: - 12th December 2006, 18:07
  5. Help with 16f688
    Last Post: - 21st October 2006, 00:12
