LCD 8x2 - SPLC780D controller
Results 1 to 7 of 7
    Hello Alain,
    I tried the SPLC780D controller, but I couldn't make the 8x2 LCD to work.
    But, my code is working fine on a 16F877 with a HD44780 controller (20x2).
    DEFINE OSC 20
    ADCON1 = 7
    DEFINE LCD_DREG PORTD
    DEFINE LCD_DBIT 4
    DEFINE LCD_RSREG PORTC
    DEFINE LCD_RSBIT 6
    DEFINE LCD_EREG PORTC
    DEFINE LCD_EBIT 7
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    DEFINE LCD_COMMANDUS 2000
    DEFINE LCD_DATAUS 50
    Pause 500
    LCDOut $fe, 1
    LCDOut "Hello Word"
    Any advice on how to configure this controller is much appreciated.
    Thanks!
    Daniel.
    Question Strange
    Hi, Daniel
    Could you post your LCD ref. ... I use every day a SPL controlled 2x16 Display instead of a classical 44780 , aboard my EasyPic5 Board.
    So, I'd recommand you to check twice your LCD Wiring ... R/W pin grounded ??? Contrast set ???
    To the end you could try LCD_COMMANDUS 2500 ... I noted my 2*8 LCDs to be a bit " lazy " ... and they need 2000 at least.
    Did you try ... another 2x8 LCD ??? a damaged device is always possible ...
    Hi Alain,
    Well, I tried 2500 on the LCD_COMMANDUS and it's still not working.
    I have a working 16F877 with a 20x2 LCD (HD44780) that works great and I use this for debbuging.
    So, I replaced that LCD with the 8x2 LCD (both have pins, so nothing to solder on them) and what it does is the following: first, all the characters on the first line went black and the it clears the screen. But. I'm not seeing the text I'm trying to write.
    This is the information I have on this LCD:
    Everything should be fine, but I'm missing something.
    Thanks!
    Daniel.
    Lightbulb
    Hi, Daniel
    http://www.fordata.cn/pdf/short/fdcc0802b.pdf
    Check the Contrast PIN ... you should have ~ 0.5 v on it ...
    Seems to be an init problem.
    What I would try is to use a huge StartUp delay... let's say 2 Sec instead of 500mSec.
    increase
    to something like
    DEFINE LCD_COMMANDUS 3000
    DEFINE LCD_DATAUS 100
    and then
            LCDOUT $FE,1
            FLAGS=0
            LCDOUT $FE,1," Hello"
    Here:
            Goto Here
    Now, Is this possible that unused data pins need to be set to GND or VDD to make it work.. that's plausible.
  1. LCD with T6963C controller
    By Demon in forum Off Topic
    Last Post: - 22nd May 2022, 20:11
  3. Need help with LCD number display.
  4. LCD will not start
  5. Dedicated LCD Controller question
    By chuckles in forum mel PIC BASIC Pro
    Last Post: - 27th February 2006, 14:44
