LCD 8x2 - SPLC780D controller
Results 1 to 7 of 7
    Default LCD 8x2 - SPLC780D controller
    Hello Guys,
    Has anyone tried this LCD controller with LCDout?
    Thanks!
    Daniel.
    Wink
    YES !
    Nothing special, just characters table slightly different ... very slightly !
    Hello Alain,
    I tried the SPLC780D controller, but I couldn't make the 8x2 LCD to work.
    But, my code is working fine on a 16F877 with a HD44780 controller (20x2).
    DEFINE OSC 20
    ADCON1 = 7
    DEFINE LCD_DREG PORTD
    DEFINE LCD_DBIT 4
    DEFINE LCD_RSREG PORTC
    DEFINE LCD_RSBIT 6
    DEFINE LCD_EREG PORTC
    DEFINE LCD_EBIT 7
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    DEFINE LCD_COMMANDUS 2000
    DEFINE LCD_DATAUS 50
    Pause 500
    LCDOut $fe, 1
    LCDOut "Hello Word"
    Any advice on how to configure this controller is much appreciated.
    Thanks!
    Daniel.
    Question Strange
    Hi, Daniel
    Could you post your LCD ref. ... I use every day a SPL controlled 2x16 Display instead of a classical 44780 , aboard my EasyPic5 Board.
    So, I'd recommand you to check twice your LCD Wiring ... R/W pin grounded ??? Contrast set ???
    To the end you could try LCD_COMMANDUS 2500 ... I noted my 2*8 LCDs to be a bit " lazy " ... and they need 2000 at least.
    Did you try ... another 2x8 LCD ??? a damaged device is always possible ...
    Hi Alain,
    Well, I tried 2500 on the LCD_COMMANDUS and it's still not working.
    I have a working 16F877 with a 20x2 LCD (HD44780) that works great and I use this for debbuging.
    So, I replaced that LCD with the 8x2 LCD (both have pins, so nothing to solder on them) and what it does is the following: first, all the characters on the first line went black and the it clears the screen. But. I'm not seeing the text I'm trying to write.
    This is the information I have on this LCD:
    Everything should be fine, but I'm missing something.
    Thanks!
    Daniel.
    Lightbulb
    Hi, Daniel
    http://www.fordata.cn/pdf/short/fdcc0802b.pdf
    Check the Contrast PIN ... you should have ~ 0.5 v on it ...
  1. LCD with T6963C controller
    By Demon in forum Off Topic
    Last Post: - 22nd May 2022, 21:11
    Last Post: - 8th August 2009, 20:54
  3. Need help with LCD number display.
  4. LCD will not start
  5. Dedicated LCD Controller question
    By chuckles in forum mel PIC BASIC Pro
    Last Post: - 27th February 2006, 15:44
