Bit Masking and Or?
Results 1 to 5 of 5
    Oct 2008
    Hi Joe,
    So....
    Data @0 , 6
    read 0, x
    Would the variable x be equal to 00000110b
    so then to make it 00100110 I would OR it with 00100000?
    Thanks, Don
    http://en.wikipedia.org/wiki/Bitwise_operation
    I am not a MATH Guy, but I believe in the example you listed, a bitwise OR would do that. Here is a link with some info. Or cannot you just add the 32 to six ?
    with PBP, 4 Bit number don't exist. I know STAMPs have Nibble variable, but not in PBP. You have Bit, BYTE, and WORD. So you could use OR or just directly set the bit you want
    ByteA = %110
    ByteA.5=1
    should do the trick as well.
