Old analog guy needs help with PIC16F57
Results 1 to 32 of 32
    Yes, same exact results as above.
    Strange. I would try another resonator or crystal.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    What code did you use?
    @ device  pic16F57, hs_osc, wdt_off, protect_off
    DEFINE OSC 20
    Time VAR BYTE
    TRISB = 0  ' all outputs
    Time = 10
        PORTB = 0
        PAUSE Time
        PORTB = 255
        PAUSE Time
        Time=Time+10
        IF Time >= 250 THEN Time = 10
        GOTO Main
    Source and .hex attached.
    Note: You can't disable /MCLR on this one, so make sure you have the external pull-up.
    -Bruce
    tech at rentron.com
    OK, when I open your code with the programmer the configuration reads:
    0000- 000a
    After I install it on the IC, then read it, this is what I get:
    0000- 0ffa
    I have no idea if this means anything or not.
    Interesting. I opened the same .hex file, and it looks llike the attached.
    hs osc, wdt off, protect off.
    Sounds like something odd going on with your programmer, or you're not
    selecting the correct PIC?
    -Bruce
    tech at rentron.com
    OK, now I'm really confused. My snappy is attached and compared to yours.
  1. pic18f analog comparator problem
    By david.silaghi in forum mel PIC BASIC Pro
    Last Post: - 6th May 2009, 10:38
  2. 16F88 Analog In
    By Mugelpower in forum mel PIC BASIC Pro
    Last Post: - 25th March 2008, 09:30
  3. Selection of analog ports
    By enauman in forum mel PIC BASIC Pro
    Last Post: - 24th December 2006, 04:56
  4. Many Analog Inputs
    By Ioannis in forum mel PIC BASIC Pro
    Last Post: - 10th July 2006, 09:15
  5. analog inputs on 16F716
    By schwinn_rider in forum mel PIC BASIC Pro
    Last Post: - 6th October 2005, 05:07
