Old analog guy needs help with PIC16F57
Results 1 to 32 of 32
    OK, I think I've found the problem. The voltage pins are in odd places on this IC, so I may have to do in-circuit programming; something else that I've never done. I'm going to figure out how to do that next and I'll get back with any results.
    Here's the code that I'll be using for a test:
    @ device  pic16F57, hs_osc, wdt_off, protect_off
    high portA.0
    low portA.0
    I'm using the old serial programmer and my first problem was not having the cable plugged into the correct header and the IC pin 1 was in the wrong place. Even now with the cable plugged into the correct header and the IC in the ZIF socket correctly, I'm getting a code programming error at 0000.
    The 16F57 is laid out really funky with Vdd on pin #2, Vss on pin #4, Vpp, pgmdata, pgmclock, etc all in odd places, so there's probably not any ZIF adapter compatible with this one.
    Wire it for in-circuit like shown here: http://melabs.com/support/icsp.htm
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Thanks again Bruce!
    Wink
    Hi Bruce ...
    Microchip AC 162049 Universal adapter CAN do it ...
    Hi Alain,
    Yep. That would do it, but it might be easier and a lot cheaper to just wire his PIC for in-circuit directly to his MeLabs serial programmer..;o}
    -Bruce
    tech at rentron.com
    Default Resonator
    OK, I made up an adapter cable and programmed the IC. I can't get it to run and I suspect the resonator or the way that I have the resonator setup. I read the data sheet and I'm thoroughly confused. I'm using Murata CSTLS20M0X53-B0 20 MHZ resonators. Is this an OK resonator and if so, how should it be connected?
    ~ Dave
    3-pin resonators normally have built-in caps. The center pin goes to ground. The remaining two pins go to the PIC external osc pins. For 20MHz you'll want HS_OSC.
    It's a lot easier for folks here to help if you show all your code & config settings.
    -Bruce
    tech at rentron.com
    Sorry ... here's the code:
    high porta.0
    high porta.1
    high porta.2
    high porta.3
    high porta.4
    high porta.6
    high porta.7
    high portb.0
    high portb.1
    high portb.2
    high portb.3
    high portb.4
    high portb.5
    high portb.6
    high portb.7
    pause 2000
    low porta.0
    low porta.1
    low porta.2
    low porta.3
    low porta.4
    low porta.6
    low porta.7
    low portb.0
    low portb.1
    low portb.2
    low portb.3
    low portb.4
    low portb.5
    low portb.6
    low portb.7
    pause 2000
  1. pic18f analog comparator problem
    By david.silaghi in forum mel PIC BASIC Pro
    Last Post: - 6th May 2009, 09:38
  2. 16F88 Analog In
    By Mugelpower in forum mel PIC BASIC Pro
    Last Post: - 25th March 2008, 08:30
  3. Selection of analog ports
    By enauman in forum mel PIC BASIC Pro
    Last Post: - 24th December 2006, 03:56
  4. Many Analog Inputs
    By Ioannis in forum mel PIC BASIC Pro
    Last Post: - 10th July 2006, 08:15
  5. analog inputs on 16F716
    By schwinn_rider in forum mel PIC BASIC Pro
    Last Post: - 6th October 2005, 04:07
