Servo reverse
Results 1 to 7 of 7
Thread: Servo reverse
    Sep 2007
    USA, CA
    3) The Pulses MUST be sent regularly @ ~ 30-50 times per second. Even if the servo has to keep on its position.
    For clarification for the less experienced...
    Alain is ONLY talking about old fashioned "cheap" analog servos. Most of the new digital servos (which aren't all that expensive, either) will accept a single pulse; they will go to that position and hold. I've used some in an application where the maintenance of an analog servo position was not practical.
    Talking nice one !
    Hi, Tenaja
    It can be a trick ... but here, it is not "genuine planned" : the servo, receiving no new pulse, keeps position as a Failsafe ...
    Not all brands do that ... so, it must be checked before use ...
    Wow,
    That was really simple, i was really getting hung up on this but i changed one side to 100 and one to 200 and it seems to work just how i want! This also got rid of the fidget in the opposite direction, except on a couple of the cheapo servos i am using but i just changed the 200 to a 190 and it stopped it from bouncing at the end.
    Thank you all very much!
    If it works now should i change it? I am using very cheap ($3) servos, and some ones from parallax and i assume they are analog.
    Thanks again
    Talking The Programmer safety principle ...
    Quote Originally Posted by bill_23 View Post
    Wow,
    Thanks again
    Generally, if a µP program works as you expected ... Do not change anything until you have a VERY good reason to change it ...
    AND Overall ... do not wipe off the first project until the new one has successfully passed ALL the "live" tests ...
  1. More Servo Woes
    By chrisshortys in forum mel PIC BASIC Pro
    Last Post: - 13th May 2009, 09:40
  2. Servo does not move
    By ruijc in forum General
    Last Post: - 12th November 2007, 20:14
  3. Beginner + Servo
    By james in forum mel PIC BASIC Pro
    Last Post: - 31st July 2007, 22:31
  4. Help with Servo Control Please!
    By wireman22 in forum mel PIC BASIC Pro
    Last Post: - 7th June 2007, 19:15
  5. Serious Serial Situation Setbacks...
